Our sequencer on our intertherm has to be replaced we lost our wiring chart to wire this back up where can we find the manuel at?
  • 96 Answers
Have you looked on the back of the cover you took off to get to the sequencers
Posted on Nov 22, 2008
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Oct 06, 2010 | Heating & Cooling
Need replacement part # and wiring diagram for Nordyne Intertherm E1EH O12HA sequencer
take it to a hvac supply house and they will match it up for you. The wiring diagram will be on the furnace
Oct 30, 2009 | Heating & Cooling
When the system is set to cool the unit will not cycle
check the ground or common wire from the thermostate to the transformer.
Apr 25, 2009 | Intertherm P3RA-048K Air Conditioner
Need help bad!!!!
try to google it at best but chances are you will need to contact intertherm directly and order one. what is wrong with your unit?
Jan 04, 2009 | Heating & Cooling
Heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Intertherm heater
You should have 24vac at the 2 lowest terminals 1 on each side of the sequencer with a call for heat.( that is the control voltage,the terminals are usually double spade brass in color) If you have the control voltage after about 30-120 seconds the sequencer should close.The voltage reading across the sequencer should go from 230vac to 0 volts when the sequencer closes.If you have control voltage and 230vac on each side of the sequencer then the sequencer is bad.It is beast if replacing the sequencer replace by moving 1 wire at a time from the old to the new.And ALWAYS make sure power is truned off.
Dec 28, 2007 | Heating & Cooling
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
