Question about Dell Dimension 3000 PC Desktop
How do i remove panel to install memory on dell 3000
I need to know how to remove panel on dell 3000
  • Anonymous Jan 29, 2009
    where to open the panel on a dell 3000 to install ram
    Sergeant:
  • 207 Answers
Countryboy,
On most DELL desktops, there is a button on the top and bottom. If you push those at the same time it releases the catch holding the case together. When they are released the case will fold open, there is no removable panel. it is a hinged mechanism.
Hope this helps you out
Dave
Posted on Nov 21, 2008
Dell Dimension 3000 will not power up. Solid amber lit stays on. Any help would be accepted.
  • If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
    • Remove and then reinstall the memory modules.
    • Remove and then reinstall any cards.
    • Remove and then reinstall the graphics card, if applicable
Refer to the link: http://support.dell.com/support/edocs/systems/dim3000/en/SM/adtshoot.htm#wp1043338
Jan 26, 2011 | Dell Dimension 3000 PC Desktop
I want to upgrade memory and need to know how to do it dell dimension 3000
HERE is a video directly from dell that outlines how to upgrade the memory in a Dell PC
Sep 01, 2010 | Dell Dimension 3000 PC Desktop
Can't open dell dimension 3000 to add memory
A tool-free side panel slides open easily to reveal a roomy interior with two free PCI slots. ... The Dell Dimension 3000 is an affordable computer designed to handle essential multimedia demands for the home user. The Dimension 3000 comes with the latest processor and memory technology, and won't break your budget.
May 14, 2010 | Dell Dimension 8300 PC Desktop
SYSTEM WILL NOT WORK AFTER INSTALLING NEW MEMORY ON DELL 3000 DIMENSION FROM 512MG TO 2GB
the new memory is not comaptible, remove it and install the old memory...it should work...RAMs are very delicate component...even though they look good some are not compatible....if u install a 400mhz RAM to a MB that can take only 333Mhz then it will cause a problem...
also if ur MB is capable of taking only 512MB per slot then 1GB in one slot will not work
Feb 19, 2010 | Dell Dimension 3000 PC Desktop
How do you remove and replace dell laptop memory? (d600)
I dont know this particular model, but usually it's underneath the computer, there is one screw to remove and you can take out a door which gives you acess to the memory slots. If it's not there, you will need to remove the top cover to get there. But it's most likely a small door underneath the laptop.
Jun 03, 2009 | Dell Latitude D600 Notebook
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Installing memory upgrade
No.
Once you install the memory into the slot the BIOS will update the memory configuration during the bootup proccess.
You can check to see if your new memory has been fully recognised by double clicking "System" in control panel.
If you check the amount of memory in System before the install and compare it afterwards you will know for sure if the memory has registered correctly.
Aug 03, 2008 | Dell Dimension 3000 PC Desktop
Installing memory
You can do this if both of your Desktops are using the same memory card or the memory card you need to replace from one to another desktop is supported by both the Desktop boards.
If you have not sure you can provide me the Model No for both the Desktops for more precise solution.
Feb 03, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
114 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
