Question about Toshiba CX32H60 TV
Color stream not working
I have a toshiba cx32h60 tv that i've had for a few years and the color stream does not work, when i connnect a device by way of component cables the picture does not show but i get a flickering color rainbow but i get audio...can you help? is there a reset function or would i have to resort to a service call of some type?
    Scholar:
  • 188 Answers
First try different cables for the video. You can use an audio cable for testing. It seems like the green channel is not making a connection. I'm assuming otherwise the set works fine?
Posted on Nov 21, 2008
Don'I have a Toshiba tv model 29L1350U how do I connect it to my wireless router
The Toshiba 29L1350U is not a Smart TV. It doesn't connect to any router (wired or wireless). You'll need some sort of media streaming device that can connect to the router. This could be something like a Roku, Google ChromeCast or Amazon Fire stick that connect to an HDMI port or one of the similar set-top boxes. Even a Blu-ray player with streaming capabilities would work. Follow the directions for powering up the device and then connect to the network using the directions in that device's setup.
You can find the specifications and manual for the 29L1350 on the Toshiba support page: http://support.toshiba.com/support/modelHome?freeText=3528910 . Click on the Manuals & Specs tab.
I wish that I had better news for you.
Jun 06, 2016 | Toshiba Televison & Video
How to hook up a Roku2 to Sony KLV-S32A10 TV with A/V cable (yellow/red/white Ports)
If you plug into the box and TV with the composite plugs then you need to change inputs. Your TV is currently set to use HDMI. You need to change the source with your remote.
Dec 25, 2014 | Roku 2 HD
Replaced power board now remote and buttons on tv somtimes work and sometimes not work
It sounds that there is some loose connnections. Check all the plug connections for any loose. Re-seat than once.
Jan 07, 2013 | Toshiba 46SL417U LCD TV
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
I have a toshiba 32a33 that uses color stream. I want to know how to use the components so that it works with a better resolution. All I can get is 480i to work.
If it has more than one color stream input only one may be 1080--or if using a box for signal that may be the issue.
You have to usually select the correct input
Mar 26, 2012 | Toshiba Televison & Video
Screen menu don't deasappear
Hello
The problem is with its main system control processor IC. You ahve to contact any experienced service tecnician to rectify this fault. It is a very skilled job.
Mar 10, 2012 | Toshiba CX32H60 TV
My tv has no sound or picture. It started last night, I went to turn it on and the red power light just blinked at me and nothing came on. I tried it again this morning and the same thing.
Lots of tvs after some years develop power supply problems, of this type, it may be capacitors drying out in the power supply, they usually swell up and deform a little. Cheap components but not a five mins fix.
not for a novice
pete
Nov 11, 2010 | Toshiba CX32H60 TV
I want to connect my laptop to my tv toshiba 37"
You might need to play with resolution of your laptop.
Display-properties-settings-resolution.
You can use S-video or S-video-HDMI cable.
Good Luck
Jan 26, 2009 | Toshiba CX32H60 TV
Sound problem on Toshiba CX2779K
Have you tryed another speaker, it could be bad also audio output ic its one of them,
Dec 07, 2008 | Toshiba CX32H60 TV
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba CX32H60 TV Logo
232 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
