Question about Magellan RoadMate 700 GPS Receiver
Mag. crosssover GPS wont reset the current location
It seems to indicate detecting sattilite covrage
MagellanGPS>com solved the problem
Posted on Nov 24, 2008
Garmin streetpilot unable to find sattilites for first 30 minutes of use
Firs of all make sure your software is up to date. Reset can be remedy to set the values to factory default. however user settings will be erased so after reset you may need to key and some user preferences. Here is the exact procedure for reset
If you need further assistance please post. After issue resolved please rate accordingly to serve you better.
Good Luck
Jun 27, 2008 | Garmin StreetPilot c550 GPS Receiver
No signal on gps
GPS units need to be updated monthly and get the GPS fix downloaded from the internet, As the GPS sattilites fly around this planet, they are not in a stationary orbit, they fly around the continental United States and you have to wait until it returns to the east coast.
Jul 01, 2011 | Tomtom ONE GPS Receiver
My Garmin 205W has been working perfect for about a year and all of a sudden cannot find any satellites to navigate on. I reset the unit to factory defaults (and yes.. lost all my "favorites")...
connect this to your computer and run a erro scan, go to computer connect the gps and run the scan, it will show up in my computer. Also do a virus scan, also you need to download the most recent GPS sattilite fix down to your unit.
Mar 31, 2011 | GPS
Will not activate with sattilite and will not stay in time
You just need to reset it. I have a 315 and if I don't use it for a while it forgets where it is and what time. So you need to put new batteries in it, reset it and then let it run outside where it can easily see the sattelites. This forces it to download the sattilite catalouge or data and resynch the time. After that it should be working normally again. This can take anywhere from 5-50 minutes which is why you need good batteries.
If you don't have your user manual you can get one free from magellan Here's the direct link to the pdf version.
http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
The reset is the same as what they call initilization. Thats on Page 4 or (pdf # 12). It's easier to follow what they have then what I can type here as there are about a dozen buttons you need to push. It only takes a minute to do but you have to follow the sequence to get it to reset.
If you don't use any gps for extended periods then they will all need to be reset and resynched to work properlly again. This is just due to the accuracy of the timing and sattelites positions. Thats for any brand or model.
Sep 23, 2010 | Magellan GPS 310 GPS Receiver
My one 125 will not update to the current time
Do a hard reset. This should force it to reload the sattilite data and update the time.
The reset for your model will be near the back of the manual. Usually is holding down a button and powering on. Then letting it run until it updates (up to an hour)
Mar 31, 2010 | Tomtom ONE 125 GPS Receiver
I have a Nuvi 200 and it has worked great until a month ago when it stopped telling where to go. It will not acquire sattilites and if by chance it does it loses them within a minute. I tried to press the...
hold the button between the arrows while turnng on device.
in mantence menu select gps menu --> perform gps cold start
press the middle button the one with 3 lines twice the switch off
go outside and switch on again satalites will start appearing
Oct 25, 2009 | Garmin nuvi 200W GPS Receiver
I have a SG5 skycaddie. It was working fine then all of a sudden I can't get my courses to show up. I get the graphics but it seems like I can't get the satellites. It just keeps searching. I have done a...
Usually when it gets lost it means its data on the available sattilites is bad or out of date. You may need to force it to do a hardware reset. You may have to take the battery out and let it sit for a day (or longer) and then reinstall and start ut up. It should then have to reload the data and work again.
If it has a backup battery you may need to take that out as well. If you do then it will only take a few minutes before you can put it back together again and get it running. I'm not familiar with this unit but the symptoms and fixes are the same as other gps
Oct 24, 2009 | GPS
My x3-t navigation system GPS freezes up
On most gps's that means it is time to reset the unit. This should force it to reload the sattilite catalog information and it should start working. Depending on the unit it can take up to an hour before it it works after rebooting while other new ones do it in a few miutes at most.
I believe this unit has a reset hole on the back so just insert somethign like a toothpick and reset it. Then place it where it can get a signal and let it do its thing. Should behave after that.
Oct 24, 2009 | GPS
Magellan RoadMate 700 GPS Receiver Logo
78 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
