Question about Canon LaserClass 2060P Plain Paper Fax
Canon LAser fax 2050P
Where is the menu button on this machine? We want to make some modifications (turn off RX Reports) and no on e can find a menu button on this. I have lifted up the cover over the speed dial buttons and gone through everything marked in there but no menu or on/off RX.
  • 2,120 Answers
It may be labeled FUNCTION
Posted on Nov 22, 2008
We have a Canon 810 Fax Machine. How can we change the fax header?
change unit name
press additional functions button
then use the arrow - + buttons to select
tx/rx settings press ok
tx/rx common set.
tx settings
unit name
page 333 or section 12
Oct 28, 2016 | Canon Laser Class 810 Plain Paper Fax
When recieving faxes on our canon laser class 2050p, the machine has a loud squeak
Your rollers will need to be replaces. Rollers feed the paper through the tray. You can find paper feed rollers for your device here:
They are very straight forward to install and instructions should be in your manual.
Mar 07, 2011 | Canon LASER CLASS 2050P
Am I able to fax to multiple recipients with canon lc 2050p?
Yes. Here is a link to your Canon Laser Class 2050P fax machine's User Guide. Reference pages 5-1 through 5-28 for Speed Dialing, One-Tuoch Dialing, and Group Dialing. Speed Dialing must be set up before Group Dialing can be assigned. Group Dialing will accomplish the multiple recipients sending.
Dec 14, 2009 | Canon LaserClass 2050 Plain Paper Fax
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
All recieved faxes going straight to memory
Either it needs toner/drum unit replaced or it's hungry for it displaying an error code?
Aug 03, 2009 | Canon LaserClass 2050 Plain Paper Fax
Canon 2050P ##323 Error
that is a heater error. the fuser asm. that melts your toner on to your paper. it is not coming up to temp. in time.
sorry to say the only way is to replase it. if you go on the internet googal canon 2050p fuser you can order one
Dec 24, 2008 | Canon LaserClass 2050 Plain Paper Fax
Confirmation sheets
Yes,press usermode go to reports and in RX report switch it to on.
Jul 11, 2008 | Canon FAXPHONE L80 Laser
Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Feb 26, 2008 | Canon FAX-L350 Plain Paper Laser
Canon LaserClass 2060P Plain Paper Fax Logo
116 people viewed this question
old marine
old marine
