Question about Denon AVR-1803 Receiver
Output from Denon D-700?
I have an older Denon D-700 stereo system, with a phono turntable attached. I am trying to record from the turntable to my computer. However, the system only seems to have input ports, not output ports. I can attach the turntable, and there are jacks for VCR connections and AUX connections. However, there don't seem to be any output jacks that will allow me to record through the amp or receiver to my computer. Is this correct? If so, is there a way I can record from the phono turntable to my Mac?
Any help is appreciated.
    Genius:
  • 1,175 Answers
Hi ...
If there's a tape monitor in/out on the D700,turn the tape monitor on and connect the "Play out" phono jacks on the 700 to the line-in on the computer. Spark up the turntable and you should be able to listen to the vinyl on the PC while recording.
Posted on Dec 30, 2008
Im trying to hook my denon stereo to my tv... can you help me??
What inputs does the TV have?
Otherwise experiment with these options:
DENON---------->>-------TV
Stereo jackplug phones out->>-RCA phono inputs.
RCA phono outputs->>-RCA phono inputs.
Stereo jackplug->>-AV.RF converter RCA phono inputs->>-ANT.in.
RCA phono outputs->>-AV.RF converter RCA phono inputs->>-ANT.in.
Nov 29, 2017 | Denon Audio Players & Recorders
Can I connect my record player to my Denon UD-M30 receiver?
If the amplifer doesn't have a PHONO input, then you will most likely need an external phono preamplifer. Most vintage turntables and cartridges have too low a signal level to connect to todays modern amplifers that don't have phono inputs. An external preamplifier will also have the correct RIAA response curve for records. Without this curve, the recordings will sound awful.
Apr 02, 2015 | Denon Audio Players & Recorders
No sound when i connect my denon-dp 29f turntable to denon rcd-m39 receiver. what might be the reason? Wrong receiver?
If your receiver ain't has a phono input and the tt has only a phono output, you'll need a phono to line line riaa amp , between the units.
Oct 26, 2013 | Denon DP-29F Turntable
Denon pma 250SE phono problem
Denon PMA 250SE does not have a RIAA phono preamp.
for some info about these preamp and details here;
Phonopreamps.com Home Page
Note: Choose a better quality regulated power supply,
for these preamps.
Although an updated turntable with USB can be used
without the need of such RIAA phono preamp.
Jul 26, 2012 | Denon Audio Players & Recorders
I just received a denon dp-45f. i am completely new to the vinyl world and honestly have no idea what i can plug it into. is it at all possible to plug it into a TV to use those speakers, or will i need to...
Yes you will need to purchase a stereo that has a phono input. If not you will have to buy an amplifier for the record player. Some newer Yamahas have a phono input. Hope this helps.
May 25, 2011 | Denon DP-47F Turntable
NO SOUND WITH EVERYTHING PLUG IN .
I assume that you're talking about the output from the 2 RCA Phono Jacks? Does this turntable output a "Line Level" signal, or a standard millivolt level 'turntable signal'? If it is an older 'standard turntable', then you need to run it into an amplifier that has a "PHONO" input and ground wire. This will amplify the tiny signal to a 'line level' signal that you can record or run to a computer, etc. If you do not have an older amplifier with "PHONO" input jacks, then you need to buy a separate stand-alone 'phono amp/preamp' that will boost your (tiny 10mv) turntable cartridge levels high enough (.5 to 1 volt) to record on another device. Let me know if that is the case. Good luck.
Jul 24, 2010 | Technics SL-1200MK2 Turntable
How do i assign a record player to ''aux ''input terminals of a denon avr 1507 amplifier
Depends on the record player (turntable). If it's old-school it will need a PHONO preamplifier to raise the level and frequency-balance the output according to the RIAA curve. Otherwise it will be uselessly low in volume and tinny sounding.
Phono preamps are available at a lot of electronics stores online. Google it. If you have an old school receiver with a PHONO function you could use IT for the TT and send its output to the Denon.
If it's a newer TT it may have its own internal (selectable) preamp. Then it would drive any standard Line Level audio input.
Apr 26, 2010 | Audio Players & Recorders
I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Jan 06, 2010 | Denon AVR-689 Receiver
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
Denon AVR-1803 Receiver Logo
250 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
