Question about Sony KP-46WT510 46" Rear Projection HDTV
No picture and 6 blinks
When the TV is turned on, there is no picture and the standby light blinks 6 times. On the service manual it states as an overload or short of the +5 line on the A,B boards. What do I need to replace?
  • 3 more comments
  • Jorge Craff
    Jorge Craff Nov 23, 2008
    Checked the boards and there are no connection problems.
  • Jorge Craff
    There are no connection problems - maybe a shorted IC? Please someone help me to check if there are bad ICs and how to replace them.
  • Jorge Craff
    The standby light blinks 6 times.
  • Jorge Craff
    Jorge Craff Nov 24, 2008
    How do I test them? I cannot find C515 or C516 - on what board would they be on - A board?
  • Jorge Craff
    Jorge Craff Dec 03, 2008
    Replaced A board but same problem.
  • 905 Answers
You can get your service manual FREE here http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
just scroll down to almost the bottom and all the way on the left hand side
so grab that then download the 10 part zip files , it says 46wt510 but when you open it here http://www.eserviceinfo.com/downloadsm/31612/Sony_KP-46WT520.html it shows you that it is for your model as well
electech
Posted on Nov 25, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your concern as you posted, the +5 is not being detected. This as you posted further could be the A,B boards. While this sound relatively simple, it could mean a variety of other things:
  • power supply failing to deliver the standby voltage, the +5, or even the 'DD 6V' Output (GM board );
  • other components/boards are clamping the +5
  • the G board is shutting down accompanied by arcing sounds.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings (Sony KP-46WT510 RA6 chassis). Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 23, 2008
  • Sony Master
  • 586 Answers
   When led blinks 6 times it means number of problems could be happend in it.And where the problem persists,This must be to define.So,+5  means that you have to check the path of +5 line.
There must be components which could be minor which is most probebly be the capacitors or Could be the Power ic.First check all the capacitors at +5 line.If not then must be the IC causing problem.
   Thanks
  • Sony Master
  • 19,396 Answers
From the service manual : Six Blinks: No Horizontal, No Raster, Check C515, C516 & Jungle Ic206.
The component to be tested are on digital board.
This is the correct information , grab the diagrams on service manual and test the components.
Source (one of many) here.
  • Ginko
    Ginko Nov 25, 2008
    They are on D board, test also Jungle Ic206.
    To test ICs you dont check continuity, you need to take voltages out, this is not a repair for a neofite.
    Call a technician, that is the best choice, or buy the service manual if you want to do it yourself.
    Master:
    Sergeant:
  • 449 Answers
Hi!!
check the board and the power supply
its maybe an overload
    President:
  • 1,952 Answers
The set has detected a problem internally and does not "start" to precvent further damage. I would check the horizontal output transistor for a shorted condition as this is the most common failure part. This is a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out of the top)
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Nov 23, 2008
    The "D" board should be labeled. Look on the boards and you should see
    large letters. In the meantime, look closely at the solder
    connections and resolder any the appear grainy or have rings. That
    will eliminate any connection issues that could complicate the
    diagnosis process. Update this with anything you find. I'll look up
    your model and get you the specific parts that may be at fault.
    The different blink codes suggest that there are connection problems
    within the set and that you are seeing diferent problems each time.
    Can you solder? If so, resolder any connections you find that appear
    have not been able to find a listing for your set from Sony. It may be
    a derivative set made specifically for one retailer and as such is only
    listed by its parent model. Be that as it may, if you have any
    experience withelectronics, I would first check the Hosrizontal Output
    Transistor for a short condition.
    Please count the number of blinks of the standby light. There should
    be a count from 1-10 or so then a pause, then the count again repeated.
    Post that here. This is the code from internal diagnostics and
    indicates the problem area
    This set may have a couple of problems. First, if you can solder, look
    for any connections on the CRT board (on the neck of the CRT) and the
    main board that look grainy or have rings and resolder them. Hopefully
    that will take care of the green problem. Next, try turning up the
    screen control on the flyback transformer. This should be the top
    control on the transformer. Turn it just a bit. If the flashing
    stops, then you have temporarily cured the problem. The picture tube
    is starting to fail. By turning up the screen control, you will have
    bought yourself time to find a replacement.
    Keep me posted on what you find.
    The most common cause of this is bad convergence ICs. These are large
    black ICs attached to a heatsink. They should be marked STKxxx. Try
    resoldering the pins on these first.
    installing a new lamp. If the lamp has failed, the set may do this.
    When the lamp hours have been exceeded, the indicator would be solid.
    The least expensive repair attempt at this point would be to replace
    the lamp.
    mohammed marika thambi Nov 24, 2008
    If you have sound, try turning up the screen control on the flyback
    transformer just a bit. See if the picture comes back. The flyback is
    the large part with the red wire coming out of the top.
    Update this with the results. , , , , , , , p
    Genius:
  • 1,550 Answers
LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards).
You need to check the boards . And check whether the connections are proper (with proper soldering)
MY SONY TV MODEL # KF42-WE610 IS SOUND IS COMING ON BUT NO PICTURE
If you turn it on and the, Power/Standby green light blinks slow 6 times; then it becomes a red fast blink 6 times, pause, then continues to blink red fast 6 times, again and again. this means when it's blinking 6 times is indication of electrical circuitry malfunction. The Television will need service.
Sep 30, 2014 | Sony Televison & Video
Sony KLV-46S200A LCD TV doesn't turn on, it remains blank with the red standby lighthouse blinking 4 times.
According to the service manual page 6. four flashes is "Backlight Trouble" so if its the light it self or Backlight Inverter Board i cannot tell you.
Service manual can be downloadet here.
http://elektrotanya.com/sony_klv-26s200a_klv-32s200a_klv-40s200a_klv-46s200a_chassis_wax2.pdf/download.html
Feb 03, 2013 | Televison & Video
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KLV-S32A10 32 when i turn on picture come then goes off
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Jun 09, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV won't stay on, Standby blinks 10 times
Its sort of silly, but my father got behind the tv and smacked it. The error message went away, and the tv is working fine now.
It wasn't easy for him to get behind it though, it's rather tall and weighs 234lbs.
I did manage to find a pdf file of the repair manual for this model at Techlore.com.
Mar 06, 2008 | Televison & Video
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony KP-46WT510 46" Rear Projection HDTV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
