Question about Sony KP-46WT510 46" Rear Projection HDTV
No picture 6 blinks
My TV has no picture and the standby light blinks 6 times. The service manual states that it is an overload or short on the +5 line on the A,B boards. What do I need to replace on the A, B boards?
  • 3 more comments
  • Jorge Craff
    Jorge Craff Dec 03, 2008
    Changed A board but no change in condition of TV - still has 6 blinks and no picture or sound.
  • Jorge Craff
    Would I check for the 5V supply problem, sensor voltage, and eprom voltage supply on the G board (power supply board)? Would changing this board resolve the problem?
  • cirssy1978 Dec 06, 2008
    kp46w510withsevenblinks
  • Jorge Craff
    Jorge Craff Dec 07, 2008
    Any word on what the test points are to determine the problem?
  • jrob617 Dec 17, 2008
    TV is only 4 years old. When you cut it on you can hear the sound but see no picture. The stanby/timer light blinks 6 times.
Kp46w510projectiontvhassevenblinks
Posted on Dec 06, 2008
  • 4,234 Answers
This could be as simple as a bad cap in the 5V supply line. If you have the service manual, check components on that supply line for shorts. Look first for filter caps tied to ground. Also, you can cehck the 5V regulator. If that is defective, it will generate the same error code.
Keep us posted.
Dan
Posted on Nov 25, 2008
  • ABRsvcs Dec 03, 2008
    Without taking measurements inside the set, no one can tell you exactly from a remote location what is the problem. All we can do is provide guidance based upon our experience in repairing these types of sets. I don't have the manual in front of me at the moment, so I can't give you specific locations. I'll look it up tonight and try to provide you with test points that should help to track down the problem.
    Dan
  • 905 Answers
  • jason Dec 03, 2008
    have you checked for a 5v supply problem?
    also check sensor voltage , eprom voltage supply , and poor solder connections
Tv turns off red light blinks 9 times
Sony tv led and blinking codes
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I hope this will be of some help to you
Mar 22, 2012 | Sony Televison & Video
No picture
can you please mention your tv model
Jun 12, 2008 | Sony FD Trinitron KV-32HV600 32" TV
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Try to turn on, it turns off right away and the stand by light flashes 6 times
Hi
Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Turn off after a few hours
If the TV turn itself off then perform the following steps:
(i) Check if the Sleep timer is activated.
(ii) Check if the Parental Guide prohibits viewing during that time and/or limits amount of viewing time per day.
(iii) Check the batteries on your remote, low battery power may cause random signals from the remote.
(iv) Disconnect all the cables from the TV then reconnect them after a few hours.
(v) Ensure the power cord from the TV is directly connected to a functional wall outlet.
(vi) You may also try resetting the TV to the original factory settings by pressing the Reset button on the remote control supplied with the TV when in Menu.
The following is the information indicated by the blinking patter of the standby/timer lamp on the TV:
2 times : Power does not come on.
Load on power line shorted.
3 times : The TV has entered standby mode.
4 times : Has entered standby state after
horizontal raster.
stopped.
Power line is shorted, or
5 times: No raster is generated.
CRT Cathode current detection
6 times: No picture
9 times : No sound
Furthermore, the TV is equipped with a self-diagnosis function that you can use to determine whether the issue is related to any hardware malfunctioning. Perform the step given below to run self diagnosis:
Quickly press the remote command button in the following order from the standby state.
Display -------> Channel 5 ---------> Volume -(minus) --------> Power ON.
If the Self Diagnosis display numeral "1" for any parameters then a fault has been detected and service will be required.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Jan 16, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Same tv
    6 times blinks shows problem can be in following areas.
    • +5 line is overloaded. (AY, BY, MY
    Boards)
    • +5 line is shorted. (AY, BY, MY Boards.)
    • IC504 is faulty. (AY Board)
    If you are tech-person, then understand easily.
    Sep 07, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Blinking Standby Light
    KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
    I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
    Jan 31, 2008 | Televison & Video
    Timer/Standby light blinks but no picture or sound when power button is pressed.
    I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
    Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
    Sony KP-46WT510 46" Rear Projection HDTV Logo
    169 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
