Question about Freezers
Chest freezer stopped freezing but boost button works
Norfrost A6AEW about 2 yrs old - I just noticed that it is not cold, but when I press the boost button it sounds like the compressor is working, but there is no noise when "boost" is turned offf. The green "on" light is not working on the unit. Any suggestions please?
5 Suggested Answers
  • 61 Answers
SOURCE: freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Posted on Oct 20, 2008
  • 389 Answers
SOURCE: I have a Norfrost 100ltr chest freezer that is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
SOURCE: i recently bought a norfrost chest freezer model
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
Posted on Feb 26, 2011
SOURCE: My Norfrost chest freezer has stopped working will
Hi. Did you solve this problem m_chard611?
I have the same problem.
Posted on Aug 01, 2011
  • 173 Answers
SOURCE: my norfrost chest freezer hardly opens.until a couple of hours?is there any timing for norfrost chest freezers?
switch of your freezer. and turn it on after half an hour. may be it works.
Posted on Dec 13, 2011
My norfrost chest freezer hardly opens.until a couple of hours?is there any timing for norfrost chest freezers?
Dec 13, 2011 | Freezers
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
May 29, 2010 | Freezers
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
My Norfrost chest freezer has stopped working will only freeze when the turbo button is switched on. Please help
which means that it is operating manualy...could be the thermostat needs replacing...
Feb 28, 2010 | Freezers
I have a Norfrost 100ltr chest freezer that is defrosting on normal setting but the fast freeze and compressor run when switched on. Any suggestions as to the problem
Jan 07, 2010 | Freezers
We got a philips whirlpool chest freezer my husband pressed orange button as he was told it was turbo boost freezers only cold at bottom and red light is on
Orange switch only by passes the thermostat. It sounds like your freezer is either out of gas or the cooling fan (if there is one) is not working.
Dec 08, 2009 | Whirlpool Freezers
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not freezing
Oct 19, 2008 | Freezers
Freezers Logo
140 people viewed this question
Top Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
