Question about Sony PSYC 177MB MD PLAYER Personal MiniDisc Player
Plays tracks in sequence
I want player to stop after track is finished
  • 27 Answers
What player? Can't respond to minimalist question.
Posted on Nov 22, 2008
Audio Books
There are several brands and publishers of audio books and you didn't identify yours. In most cases professionally produced audio books are separated into several 3-6 minute tracks. your CD player should just skip to the next using the button with the single arrow pointing to the vertical line. >l
When listening to audio books, If I'm using a cd player that doesn't retain the last track when shut off I make a mental note of the track number.
Hope this helps
Dec 14, 2013 | Coby CX-CD329 Personal CD Player
SLP 222A CD Player - about 25 years old. CDs click/stall/skip on the first minute or so of every cd but play fine throughout the rest. This happens to the initial track/start of every CD even if this part...
As the disk rotates faster in the centre, (track 1) than the later tracks, the spindle motor may need replacing as it can't achieve the correct speed or there is something stopping the laser from focusing correctly at the beginning of the disk. Fluff or a fine hair maybe.
Lens cleaners do not work.
Jan 06, 2018 | Technics Audio Players & Recorders
Cd player starts, but stops play by 2nd track
Sounds like tracking motor and/or gear problem!
Check for a small crack on the tracking gear.
Parts not avalible from Bose though, they'll only
fix as a "flat rate"!
Apr 12, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
Hi I have purchased 5 x Thomson 6677 mp3 players. They are a cheap little 1GB player which I planned to use as give aways for business development with audio material about our company...
try relabeling the tracts in the following order. 01,02,03 etc. Reason the indexing on the device might be set to rearrange based on single numbers.
hope this helps.
Aug 19, 2009 | Audio Players & Recorders
Tracks played in wrong order
The Sony NWZ-S616F (4 GB) sometimes plays the musical tracks out of sequence. To check if the tracks are being played correctly, press the down arrow key ↓ at any time until the name of the book or music is selected. Then press the ► button and the tracks will show up. If they are in wrong order, select track 1 and press ►.
Feb 19, 2009 | Sony Walkman NWZ-S616F MP3 Player
Switch bwtn CONT or SINGLE play on Denon's DN-C615
Try this:
1. While holding "Title", Press Stop to enter what Denon calls "presetting" mode.
2. Press Track Search Reverse or Track Search Forward until you get to 20, which is the presetting mode for Single/Continuous Play.
3. Press Play to toggle between Continuous and Single Play.
4. Press Stop to exit Presetting Mode.
Hope this works! I just finished a belabored job without Single Play on this unit. I have been searching for the answer too. I don't have access to the deck to try it, but I think this will do the job.
Dec 23, 2008 | Denon DN-C615 CD Player
No license to play track
That means you will have to sync your devicce in oder to play the songs on the device..what you will have to do is to transfer one new track that you download to your device...then once you finish transfer it the tracks, it should update every single tracks on the device...if that doesnt solve the problem you are having..what you will have to do is to format the player using windows media player then once you format it transfer the tracks over and the should be playing...
Hope that helps
Thank You
Computerrep
P.S...Please rate accordingly..
Dec 20, 2007 | Dell Pocket DJ MP3 Player
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
