Question about LG Vu CU920 Cellular Phone
Memory card format for lg vu 920
How do I format a 4gb memory card for my phone?
Please advice.
  • 2 more comments
  • olli400 Dec 02, 2008
    I have the same problem, but there is no option for "Removable disk" under "USB Connectivity"; there is just an option for "Music Sync". When i connect my phone to the computer using a USB cable, my phone says i have to format the memory card, and my computer does not detect the memory card at all. What should i do?
  • rlmazac Mar 11, 2009
    cant figure out how to format a memory card that came out of another phone and is going into an lg vu
  • jess_mustang May 18, 2009
    I have the same problem only mine is an 8 GB...will it work the same for me?
  • Anonymous Mar 16, 2014
    When I tried to register my first edition Kindle Fire, I received the message'The e-mail address is not formatted correctly.
    Problem Solver:
  • 8 Answers
Usually to format a disk, memory card; anything, you need to be plugged into a computer.
Which requires a USB cable for your phone, or a card reader. If you don't already have a USB cable, it's usually easier to come across a card reader simply because everybody uses them. With a USB cable, most stores don't carry them and have to order, because it's specific for a phone.
Now if you have a USB Cable or a card reader already, plug it into your computer. (With the phone, make sure the "USB Connectivity" settings are set to "Removable Disk". This way, it won't read the phone's memory, just the memory card.)
Once the memory card is detected, right click on it, and there should be an option that says "Format". Click it. You should get a popup asking if you're sure or not. Obviously you're serious about formatting the card, so click yes.
There's a check box for "Quick Format". It's a sort of way of half-assed formatting; it's faster, but not as thorough. Whether or not you do that is up to you.
Posted on Nov 24, 2008
How do i format a memory card for the lg vu 930
Hi there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 12, 2010 | LG Vu CU920 Cellular Phone
    My lg vu will not recognize my memory card. I have a micro sd 8g card. Does this phone only recognize a smaller card?
    Sir,
    Yourcell phone supports only MicroSD in it so you can purchase the card by the this name "MicroSD" Your card may not be recognized if its corrupted or have any other format then"FAT" please observe "FAT" not "FAT32".
    Oct 25, 2009 | LG Vu CU920 Cellular Phone
    I have an lg vu and the usb cord but no memory card can i still put music
    Even if you have USB cord or bluetooth you should have some memory in your mobile to load music files.But you can extend your memmory using memory card. The list of memory cards available fo ryour model is seen here: http://www.accessorygeeks.com/lg-vu-cu920-memory-card.html
    Rate me if it is helpful!!
    Aug 20, 2009 | LG Vu CU920 Cellular Phone
    Write protection on memory card sd
    try formatting memory card from your mobile then use it on computer
    Jun 17, 2009 | LG Vu CU920 Cellular Phone
    How do I format my sd memory card so I can save pitcures from the phone to the card?
    THIS WILL MAKE YOU LOOSE ALL FILES!!!
    (even password)
    Take the memorycard out of the phone and,
    put it in a computer.Use filesystem FAT-32
    to reformat your memorycard.
    Now the card will work again!
    No password, No files will be left after a
    complete reformat
    This is your solution! Please vote!
    Apr 19, 2009 | LG Vu Cellular Phone
    My lg vu wont turn on
    If you have a memory card installed, try removing it and then reseating the battery. If the problem goes away it is something to do with the format of the memory card. There are some solutions out on the internet: http://www.lg-vu.com/index.php?action=printpage;topic=2662.0 but it seems unclear as to effectively fix the problem. It seems a clean fat32 format is critical for the memory card but there by other issues. Hopefully LG will acknowledge and fix this soon.
    Feb 01, 2009 | LG Vu CU920 Cellular Phone
    8gb micro sd card does not work. lg vu cu920. is there a fix
    I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
    Jan 26, 2009 | LG Vu CU920 Cellular Phone
    How to format memory card
    in most lgs u can go to the menu and then settings then memory and then go into card and select format then it shud b good
    Dec 04, 2008 | LG Vu CU920 Cellular Phone
    LG Vu CU920 Cellular Phone Logo
    3,255 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
