Question about Kenmore Elite 45986 Front Load Washer
Not sure about dishwashers
Iam not really sure if there is a problem or not, it hasn't been working right for a couple of days now. my ? is how many filters are there in them, is there a filter before the pump? that can be full of pieces of food or something on that line. thank you jeff
  • 61 Answers
It depends on the manufacturer if it is a frigidaire the filter is located in the hose that goes from the pump to the tub. if it is a whirlpool then there is a filter that you can remove directly in the front of the pump. Kenmore is a name only it has other companies make the machine for them.I hope this info helps
Posted on Dec 17, 2008
A couple of times I've found that the dishwasher tablet I'm using (Finish) hasn't dissolved correctly. I found it in the cutlery box the last time. I've been putting it on the 65 degree...
I am guessing you are using the Centigrade temperature scale ... which would be 149 degrees F. 149 is way hot in terms of regular house hold use. Probably just right for a dish washer.
I would expect most tablet detergent would disolve properly at this temperature and with proper water pressure in the machine. You should have plenty of both in this machine. May I suggest you give liquid dish washer detergent a try to see the results?
Jun 01, 2011 | Dishwashers
I have a hp 2207 monitor was working fine then we cut it off one day before a storm and since then it hasn't worked the blue power button at the top flashes on an off and the monitor flickers in and...
Not sure how much this will help you now, but unplugging your device is the only way to really protect it during a storm. Even turned off, your equipment is still subject to receive any electrical spikes that come through the lines
May 09, 2011 | HP w2207 Monitor
The dishwasher will start for two sec and then they both stop and a red light comes on and starts beeping with motors running.
This indicates the flood switch has been tripped. The video in the link below explains how to access and repair single and double drawer fisher and paykel dishwashers. Its a really good Fisher Paykel dishwasher repair video it really helped me.
Fisher Paykel Dishwasher Repair Video Link
Mar 09, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Starting Knocking of the engine when cold
if iam not mistaken here and no doubt i am but without hearing the noise i cannot really say but i would hazard a guess and say its a hydraulic tappet clacking and to cure this you will need to add a couple of capfulls of washing up liquid to the oil and half a pint of diesel as well .Run engine for a couple of days and if iam right the noise will stop ,When it stops drain the oil and change it for a new filter and oil ,then make sure you change the oil every 6000miles and the filter every third oil change this will prevent the build up of clagg inside the engine blocking things up .
Nov 29, 2010 | 2004 Jaguar X-Type
Dishwasher top drawer was dead so i was told to change the heater under the drawer i did that but now i got more broblems the top drawer lights up just beeps for a second and does nothing as for the...
Whenever the Drawer is Dead, there could be a couple of Reasons. First, it could be a Bad Heater Plate or Bad Control Board on the Front.You could remove the Control Board and Check.More often, you would find visually, that they are Hot and Bad.
On Few Models, there are two Circles.You could use a Pliers and twist them out.The Front will Slide and you could check all the Connections.Make sure they are tight and secure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My kenmore ultrawash quitequard 3 is not cleaning or heating up
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
ggjk
Feb 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
HOW TO REMOVE THE SPRAY ARM FROM MY DISHWASHER
Hello kimic72,
Welcome,
You said, at first my i noticed that it looked as if the dishes weren't getting rinsed thoroughly, there was a white film and we have been using the same detergent as always, i read that sometimes it could just be that the controls weren't contacting properly and to just mess around with the buttons and it could help, that actually worked, now its not draining and i wanted to see if it was some sort of timer problem since my buttons don't always contact before i start check in everything else i don't think its clogged but really iam not sure, anyways it could be so many things i read that u can get to the pump or something from the inside after removing the spray arm but im not sure how to get it off if u could please help thank u
Please provide the model number and yaer of your dishwasher and I will attempt to assit you!
huuum
Waiting your response
Oct 17, 2008 | GE Dishwashers
I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Jul 26, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Pump comes on but no water comes in
check the water inlet valve for proper voltage if you have voltage the water inlet valve is bad
Apr 29, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
