Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Bissell 1697w Powersteamer
I have the Bissel 1697w from Walmart. It has been used a few times, but now the water solution does not spray. I turn it on and the brushes turn, but when I pull the trigger, no water. I took it apart but failed to see anything that looked wrong. Any ideas?
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Posted on Dec 22, 2006
It worked but had to do it several times to get mine to work. It still has the problem but I think one of the lines may have sprung a leak. It seems to be leaking soapy water on the side of the detergent container.
Posted on Mar 18, 2007
2 Suggested Answers
SOURCE: Bissell 1697w Powersteamer
http://www.bissell.com/images/UserGuides/1697_207.pdf
go to bissell.com on the right hand side is the link were you type in your model number. it will take you to it you click more info and it opens a page to access the user guide. i had the same problem and after looking at the user guide found i had a broken belt (near the flow indicator there is a section that can open use a flat head screwdriver to pry it open and you can see the belt) i dont know if that will work yet b/c i just found it so im on the way to get a new belt. hope this helps
Posted on Sep 10, 2008
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
I purchased my Bissel PowerSteamer Clearview a few years or so ago, and cannot find where I filed the manuals. If I find the actual seriel number on the Bissel PowerSteamer Clearview, Is there a way that I...
No need my friend. Go here. All documentation is here...and....it's free! Hope this helps : )
http://www.bissell.com/user-guides/?searchtext=1699%2520pro%2520heat&searchType=search&mode=228
Jan 07, 2011 | Bissell 1699 ProHeat Clear View Upright...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water does spray out when using floor bissel proheat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Mar 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have had my Bissel Powersteamer Pro (green) for a few years, but have never used it. I can't find my manual and I have no idea how to use it. Help!!
fill reservoir with water and solution. Then you can push release trigger and vacuum . Don't over fill and do not let stay in one place too long as it will soak area. It takes a feel to get used to.
Mar 07, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel 1695 - pump not turning on. Vacuum turns on
bad switch or connecter at switch or the pump is plugged
Feb 22, 2009 | Bissell 1695 PowerSteamer Vacuum
Jul 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
751 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
