Why did my washing machine Motor capacitor burn out
I have a Whirlpool top load washing machine sometimes does not move to the next cycle..i have to hold the nob out to allow it to change cycles or change through them by stopping and turning to next one...i can hear the timer and it trying to cycle... today i saw smoke so i unplugged the unit and opened up the top and my capacitor was smoking and dripping liquid i know that i have too replace it but i would like to know why it burned out...It is old and now a fire hazard... i just want to know what happened so it does not happen when i buy a new one....
thank you for taking the time to read this message..
sincerely
The guy thinking about buying a wash board and ringer...
  • Anonymous Jan 22, 2009
    I have a top load washing machine, sometimes does not move to the next cycle..i have to hold the nob out to allow it to change cycles or change through them by stopping and turning to next one...i can hear the timer and it trying to cycle... today i saw smoke so i unplugged the unit and opened up the top and my capacitor was smoking and dripping liquid i know that i have too replace it but i would like to know why it burned out...It is old and now a fire hazard... i just want to know what happened so it does not happen when i buy a new one....
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
oscarn
  • 110 Answers
SOURCE: Whirlpool LGR7648KQ1 top loader washer
Hi It appears that- You have a clogged water pump inlet filter. Normally located at the bottom of the machine there should be a 1"-2" disk that you need to rotate half turn to release. Be aware that a large quantity of water is likely to drain when you open it. Good luck
Posted on Sep 07, 2007
jsrock516
  • 5911 Answers
SOURCE: Washer leaks during wash cycle
Taking a top loader apart is simple if you follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
The drain pump is the most common cause of leaks. It will be located in the front of the washer. Check the drain hoses and clamps as well. If the pump is leaking, it is NOT serviceable and cannot be repaired. It must be replaced.
Check the wash tub to ensure there are no cracks causing the leak.
To reinstall the outer case and components, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall operator console.
This is not a difficult repair, but if you have questions, please let me know.
Posted on Apr 27, 2009
rylee_smith
  • 8619 Answers
SOURCE: Frigidaire FWS833AS1 - My washing machine recently
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 16, 2009
  • 38 Answers
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Posted on Dec 29, 2009
Direct drive whirlpool washer has electrical odor and stops.
the burn odour and stoppage an electrical fault and coupled with a 20 amp circuit breaker tripping indicates a motor fault
Capacitors are tested with an capacitance tester and not an ohm meter as ohms is a resistance and not capacitance reading
When breakers activate it indicates a massive short or current draw and the problem could be in the windings of the motor
could be water getting into the motor at times causing the intermittent problem
I would suggest that you call in a service technician or an accredited electrician to check out the machine properly
Jan 20, 2016 | Whirlpool Washing Machines
Whirlpool cabrio washer
Looks like the motor is having a hard time starting. Try changing the motor capacitor, it jump starts the motor. It is cylindrical in shape aluminum color, sometimes black or may even be plastic white. Also, if it is not a direct drive, inspect the drive belt it could be worn out.
Aug 25, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washer went dead during fill cycle
Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Will not drain and move to next cycle/Lt700xv
Machine washes but will not drain then moves to the next cycle, What do I do?
Feb 08, 2009 | Whirlpool LTE5243D Top Load Stacked...
Won't spin or agitate
Sounds like a burning out motor to me...
Jul 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont run but is trying to
Sounds like the motor or capacitor (next to the motor), the capacitor helps the motor to start, once running a switch inside the motor disconnects the capacitor from circuit.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
1,199 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
