Question about Maytag Neptune MAH5500B Front Load Washer
I cannot get the drive belt back on my Neptune washer
It will not stretch between the drive pully and motor pully. There is no belt adjustment wheel on the drive pulley.
  • 370 Answers
Its not an easy task but you have to barely get one side to hook or touch the pulley and then roll it on. When you get it started it should roll on pretty easily
Posted on Nov 21, 2008
Neptune washer will not extrACT water
Not belt or pulley!
Pump located below drum blocked or filter blocked
May 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
Will not spin
The pully belt on the back of the machine has come off.Take the lid off or the back panel off if this model has a back panel.locate the belt probably on the floor check condition if ok just put back on it stretches over the wheel on the back of the tub & the prong at the back off the motor.
Feb 06, 2012 | Samsung WF203ANW Front Load Washer
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
How to replace the belt on a beko washer
Hithere.......the belt used on these machines is a stretch belt...ie...it will require a little determination to fit it......Isolate the electricity from the machine....remove the top lid.....remove the rear inspection panel...(5 screws) from the top of the machine offer the belt down to the motor pully...fitting it over the pully (middle of the motor pully)...bring the belt as far around the drive pulley of the washer as you can...then holding it in place gently turn the drive pulley this action will bring the new belt fully over the drive pulley...check and aling the belt in the middle of the washer pulley
BE RATHER CAREFUL NOT TO CUT OR LACERATE UR HANDS
Regards Sir Galahad
Aug 16, 2009 | Washing Machines
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
Belt slipping off of pully on maytag neptune mah5500bww
I loosed the moter and the belt is staying on. However, my belt is cutting the tub when the belt is moving off the pully.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH3000AWW Pullys dont line up
Found that the rear bearing was bad, did not want to spend big money on very old machine so just replaced it.
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
I cannot get the drive belt back on.
Hi.
Asuming you have the correct belt, then you will really have pull and stretch it hard to get it on.
It is the case that the new belt wiill not appear to be the right size.
Just persist, mind you do not trap your fingers!!!
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
