Question about White Sewing 1418 Mechanical Sewing Machine
Bobbin issues My machine was working perfectly fine when i had to add more thread to my bobbin. Now the bottom thread will not feed through. this is a new machine. i have oiled everything where the bobbin sits in and cleaned the area. i also changed needle because it also broke.
I bet you have put the needle in the wrong round, most common fault, check it and see, don't put too much oil in the bobbin case area, Ken drivewithken@blueyonder.co.uk
Posted on Sep 18, 2007
Bobbin thread is not being picked up when I free motion quilt
Duh. It was the breaker. Always check the breaker ...especially around Xmas!
Dec 04, 2013 | Janome Memory Craft 9000 Computerized...
When attempting to free motion quilt, bottom thread is not being picked up
You must lower the presser foot to use the free motion/darning foot.
Dec 04, 2013 | Brother Sewing Machines
My minghui is sawing just top and bottom is just mess can u help me???
Thanks for the question.
If your machine is not sewing on the bottom or making stacks of thread called (bird nesting) there are several simple fixes for this and some not so simple.
First you need to make sure that you are threading the bobbin into the holder correctly, Insure that you pull the end of the thread through the little slit on the side of the bobbin and that the thread is somewhat snug but not hard to pull.
Once you have done this replace the bobbin in the bobbin holder and thread the feed thread over the top from the spool or thread. making sure that you run it through the auto tensioner.
Set the auto thread tension to +1 to start, go ahead and thread the main feed through the bobbin feed so that you have both strings on the sewing deck.
Now with a piece of used material, pull both bobbin feed and Main thread behind the machine, insert your test material, drop the material tension foot onto material and start to sew a 1 inch spot.
After about one inch check to see if your machine is still nesting thread, if it is you need to add more tention to the main thread by moving the auto tensioner to +2. Now test sew again a short distance and recheck. If you still have a issue move the tension up until the nesting of string stops.
If you reach the stop. than it\'s likely that the bobbin holder needs to be adjusted.
The bobbin holder has two small screws in it generally that allow a very small screwdriver to adjust the bi metal pensioner on the bobbin holder. This is the area where you slide the string through the little slot in the bobbin holder.
You can tighten those screws until the string is harder to pull out of the bobbin holder. You may have to repeat this step several times until you get the tensions just right.
but make sure that you reset the main Thread tension to 0 before you start adjusting the bobbin tension.
If after all this work fails you may have to replace the bobbin holder to correct this issue.
There is one other fix that you can try before replacing the bobbin holder and that is to purchase more expensive thread. The reason behind this is that the more expensive thread is thicker and causes more friction in the bobbin holder..
I hope that this has helped you, I know what it\'s like not to have a working sewing machine.
Best of luck and thanks for using Fixya.com
Oct 16, 2013 | Sewing Machines
Singer - 241-12, bobbin thread not stitching
I have a 241-12 Singer. New to me. It was running great. Then the bobbin thread ran out. Put in one prewound bobbin that came with it, even though the bobbin appeared different. The bobbin thread didn't feed and the machine jammed up. I finally wound the old bobbin and put it in. It will only feed about 6" of thread before the bobbin thread breaks. It becomes so tight I can't get it to feed. Both bobbins will not feed. However I don't believe it's the bobbin tension because thread will pull through fine when pulled manually (if it hasn't been in the machine yet). What am I doing wrong?
Sep 15, 2013 | Singer Sewing Machines
My White 5500 sews perfectly on the top, but the bottom thread is tangled and messy. I have tried to adjust the tension according to the manual but nothing seems to work. Help!
This is a really common problem especially on side bobbin machines, and the manual will tell you it's a tension problem but it's often a more general thread feeding problem. First make sure you have a good quality thread that isn't old or sticking as it comes off the spool. And more important it can't be too heavy, especially in certain fabrics and with a fine needle. A too heavy thread will cause all the problems you describe.
If your machine uses a bobbin holder and it has a tensioner in it make sure it's clean and well adjusted and has no gummy residue on it. And finally look at the bobbins themselves, I understand older machines work better with metal bobbins vs plastic.
These are very generic solutions but I had similar befuddling problems with a newer Brother side bobbin machine and was tearing my hair out over the thread bunching and Brother support kept insisting it was a tension problem or improper thread routing.
Turned out I was using too heavy a thread.
Since then I picked up an older (1990?) Singer Meritt 4530 from Goodwill for $20, but it's a more expensive top bobbin machine and NEVER bunches or malfunctions. I'm sold on the top bobbin design now, the mechanism inside is more complex but the thread feed from the bobbin is more direct and simple leading to less sewing issues. So you pay more for less headaches.
Jun 01, 2011 | White Sewing Sewing Machines
Brother CS-8150 Problems with bobbin thread
Double check to see if the bobbin is in upside down and the thread is feeding from the bobbin spool in the wrong direction.
I did this once after several years using the same machine, some days are just not as easy as they should be!
Mar 04, 2010 | Brother CS-8150 Computerized Sewing...
When i sew, the stitching on top is perfect, but the thread is all bunched and loose on the bottom.
Your bobbin may not be threaded through the bobbin case correctly, OR the tension on the bobbin case my be much too loose allowing the bobbin thread to pull out too quickly. There should be a tiny screw on the bobbin case that you can adjust to allow the thread to feed smoothly without catching & yet not pull out too freely. You may have to try this out on a scrap piece of fabric to find the perfect setting - both sides should be smooth without pulling from either direction. Oh - typically turning to the right tightens, left loosens ie: "righty-tighty, lefty loosey" best of luck hope this helps!
Nov 11, 2009 | Singer 3116 Simple
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
Bobbin tangle
can not thread bobbin...bobbin on top
Jan 16, 2008 | Kenmore 19233 Computerized Sewing Machine
White Sewing 1418 Mechanical Sewing Machine Logo
134 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
