GE Front Loader WSSH300GWW
Whenever we wash hots (primarily towels and bedsheets) the items stink terribly. After the clean towels are on the closet for a day or two, you can't open the door w/o losing your breath. We tried using more soap and fabric softener, but it doesn't work. We have gone so far to throw away all of the older towels and replaced with new thinking/hoping they had some sort of bacteria in them. Guess what...the new ones stink now too.
We've tried running bleach and vinegar (separately, of course) through an emply cycle, but it has no effect. We did not have this problem with our last washer. Any ideas?
On another note - how difficult is it to replace the control board in these machines? The lights are constantly blinking and the thing beeps excessively. I ran the diagnostic and it says the board needs to be replaced. Any advice/ideas are appreciated.
  • Bama2000 Dec 16, 2008
    I have noticed something similar in that the washer remains wet on the inside and smells horrible. It never dries out fully on the inside and algae is starting to grow and smell inside it. We immediately dry our towels and clothes and have not noticed the smell with the clothes, other than the smell of the fabric softener.
  • Anonymous Jan 11, 2009
    We have the same problem with our GE front loader purchased in 2006. We're tried everything (leaving the door open, leaving the soap tray open, cleaning the gasket after each cycle) yet it still smells awful. We also periodically run bleach through the machine.
    I like the cost savings, but would not recommend a front loader to anyone else. We'll go back to a top loader when this one dies. An expensive lesson learned.
    Also, the cycles take a really long time (over an hour), which is not practical for a family.
    We really miss the old fashioned top loader.
the dr
  • 447 Answers
SOURCE: Maytag Washer, Model # MAH4000AWW (Neptune - front loader) appr. 4 yrs old
Hi john, There is a blue cover that i am suspecting you are missing from the softener/bleach dispenser. It fits over the two tubes in the dispenser and it siphons the water out. It is part number 22002266. Also the machine has a water filled balance ring. It is normal to hear sounds of water when the tub is turned. If you can see water in the spinner its a different story.
Posted on Nov 24, 2007
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
IFIXALL
  • 868 Answers
SOURCE: Have a maytag neptune washer
start leaving the door open from now on.
Posted on May 31, 2008
  • 489 Answers
SOURCE: Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Posted on Jun 11, 2008
onthejob5130
  • 640 Answers
SOURCE: front load maytag duet odor
well you have a filter down at your toe panel,,maybe it time to clean it..
Posted on Jan 03, 2009
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
Causes of washing machine smell. What will remove the stink?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 04, 2010 | LG WM1812C Front Load Washer
Front loader wash machine (Maytide) has a terrible odor, even if the door is left open. Have cleaned it out with clorox and even the cleaner for front loader but with no success. Any solutions?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Sep 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
Clothes smell bad in my GE front loader.  It's one of the first models they came out with - about 3 years old.  Thanks.
Run the unit through a cycle with HOT water and a small box of baking soda plus detergent--no clothes. There are a number of cleaning products on the market that do the same thing (but more expensive). Redo this whenever you notice the smell returning.
Aug 04, 2009 | GE WSXH208A Front Load Washer
Odor in front loader
Jul 05, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Front loader washing machine stinks really bad
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Mar 30, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Sport? Front Load Washer WFW8300SW
hate my duet sport also! You cant presoak in this machine, very little water to wash with, very noisy, and everything stinks when it comes out of washer. Mine also smelled like mold but i figured out if you pull out the little tray that holds the detergent it is filled with stinky black mold. would never buy again
Jun 18, 2008 | Whirlpool WFW8300SW
HELP!! Kenmore Elite top load STINKS during use
Apr 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
