Question about Brother SX-4000 Typewriter
Cutting off bottom of letters
Tried taking out wheel, tape and correction and reserting and still does it
  • Brother Master
  • 3,594 Answers
Look at the ribbon and see if the letters are in the center of the ribbon. If not you have a ribbon lift problem. If they are check to be sure the platen is fully seated in the side frames.
DickyO
Posted on Nov 21, 2008
The correction tape is not woring
Take ribbon out type a small amount of charaters then do a correction and see if the wheel goes around, if it does motor is Ok the it could be a bad ribbon cassette.
Apr 09, 2014 | IBM Wheelwriter 30 Typewriter
I have an Olympia Standard elec typwriter. Does anyone know where I could find someone (NE London for pref) who could correctly install one of my replacement cartridges and correcting tapes. As it is,...
I think the reason why the tape is no longer rising up is due to the failure of the orange cog at the bottom of the carriage (just under the printer ribbon). This stops the carriage rising.
Can you inspect the cog and check it is intact? Also look at the bottom of the typewriter inside an look for sheared off organge teeth
Let me know if it's that issue and I might be able to give you a solution
Sep 10, 2010 | Olympia Mastertype 3 Typewriter
Wheelwriter 35 cutting off bottom of letters
First thin to do is to be sure the platen (rubber roll) is fully seated in the T/W side frames. press firmly on both ends of the platen.
DickyO
Mar 02, 2010 | Lexmark Wheelwriter 35 Series II...
I have a really old SD 660 and I no longer have manual. It is printing great but it is not typing correct letter for example when you type a it prints the letter p and so on?
Remove the printwheel check for bent spokes, look for debris in that area, try it without the correction tape, check that the correction tape is dry not tacky, also check to see if the pitch selection isn't in PS proportional space. If allis good the homing pawl spring is probably broken, you need a tech.
DickyO
Jun 26, 2009 | Smith Corona Office Equipment & Supplies
Warning sound, didn't move
Check to be sure the correction tape isn't tangled in the print wheel. If it is or was check the wheel to be sure it isn't damaged,
Then try it without the correction tape.
DickyO
Apr 04, 2009 | Brother SX-4000 Typewriter
VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Jan 02, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Wrong letters typing
it sounds like you were using a non-brother correction tape,one that was too sticky and consequently too "slow" and during the correction sequence the fingers of the daisy-wheel got entangled with the tape. Make sure that the correction tape is of a "non-sticky" nature and then take off the correction and printing tapes. That way you will see better how the daisy-wheel is fitted . I will assume that you have an instruction book to show how this is done. before fitting the daisy wheel examine the fingers to see that none are bent or crossed over each other. If this is the case it is better to buy another one. bring your typewriter to the shop if this is the case and they will possibly re-fit the wheel for you. good luck.....
Mar 19, 2008 | Brother ML-300 Typewriter
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Random letters/correction tape
You must have damaged the Daisy Wheel when you were fitting c'tape..Fit another wheel..
Apr 10, 2007 | Brother SX-4000 Typewriter
Brother SX-4000 Typewriter Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
