Question about Infinity BU-1 Speaker
Infinity BU1 Powered Subwoofer
My BU1 powered subwoofer has a 120V 1A slow blow fuse at the point of power entry. That fuse was blown. I purchased a new fuse and when I plugged in the speaker the power light came on and immediately the fuse blew again. I don't have a schematic to know how to test the circuitry. Do you know if one is available online in a Word or PDF format?
  • ramleda Dec 04, 2008
    I have the same problem. I want to know the complete description of that fuse because I lsot mine. That's a ceramic type fuse and not the glass type sold by Radio Shack.
4 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: infinity subwoofer in surround sound system was
Check your speaker settings on the main menu of the receiver first. If you still have an issue, post a comment and I will help you troubleshoot some more
Posted on Jul 27, 2009
fkuk
  • 311 Answers
SOURCE: Can I replace the sub woofer in my home stereo
if the impedance of the new speaker matches the impedance of the old one then i dont see why it wont work
Posted on Jan 01, 2010
  • 5 Answers
SOURCE: HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Posted on May 18, 2010
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
Where to purchase vertical mounting feet & bolts for Infinity sub
Simple as it sounds, try Home Depot/Lowe's! They will have them! Been there, done that!
Mar 30, 2010 | Infinity BASSLINK Car Subwoofer
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Infinity Interlude IL120s Powered Subwoofer (home) will not power
Some of these Infinity Amps have an Internal Glass Fuse. Open the Case and Check for this Fuse. Please Rate My Response! Thanks!
Feb 03, 2009 | Infinity 7540A Car Audio Amplifier
Infinity Entra Sub 150 no sound or power
I had the same problem. When I opened it up, the fuse was blown, and it was a pain to find the fuse it needs (3 Amp, 250 V slow-blow fuse, 5x20 mm). Also, the 2 large electrolytics (big purple things near the amp) and one small capacitor were all blown. For 4 fuses, bought seperately from, and the 2 electrolytics and 1 capacitor, it cost about $20, plus almost 20 more in shipping, which still isnt bad considering the original price of the sub. However, the tricky part is that you have to know how to use a soldering iron to take out the old components and put in the new ones.
Jan 01, 2009 | Infinity Entra Sub Subwoofer
My Velodyne CT 80 powered subwoofer does not power on?
Fuse in amp may be blown or the amp is dead
Contact Velodyne, the replacment amp is not very expensive
Sep 03, 2008 | Velodyne Audio Players & Recorders
Basslink
make sure ur ground cabke is as large if not larger then ur poweer cable.
Oct 11, 2007 | Infinity BASSLINK Car Subwoofer
818 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
