Question about Gateway (4000274) Motherboard
500c CTO will not boot
I have a Gateway 500c CTO When compter is plugged into the ac outlet, the power supply fan starts immediately without pressing the front on button. There are no "post' signals or the display does not come up. The power supply was found to operational (all voltages are present).
  • Gateway Master
  • 4,806 Answers
Check the RAM, processor etc, disconnect all the hard drives and check the on/off controllers on the board
regards
Posted on Nov 21, 2008
Wont start
Gateway user guides are available at Gateway's web site. You need your compters information to access it.
Looks like a power supply issue.
Apr 13, 2014 | Gateway M-6750 PC Notebook
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
When i plugged power cable to my pc cpu fan start without press power button
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
Apr 03, 2011 | Intel 845GE Motherboard
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
Lighting came into my computer via the ethernet cable. can this be fixed I also think it took out my power supply un it. It is a gateway 500c.
If only power supply's affected, then change the SMPS with a compatible one of the same rating. But first check the monitor by connecting to the mains power supply with the video chord not attached to anything. if the monitor displays "no videos" signal, then the monitor is OK cange the SMPS of the CPU and check UPS & spike boards fuses, otherwise commect to main power supply pluf(Wall 3-pin outlet socket)......sodeep
Jun 09, 2009 | Gateway (4000274) Motherboard
Gateway 500C CTO want to replace motherboard
it depends on how mutch you need your files from hdd,
if bord is a p4 and you can find a cheap 1 (on ebay.ect)
it wownt be so bad,
May 08, 2009 | Gateway (4000274) Motherboard
Front panel Ac Switch failing to start computer.
Try these steps.
If Power supply light does not turn on (or no power supply LED)
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
NOTE: If the Power Supply fan spins when the PC is turned on but the light does not come on, it is possible the LED is defective. If this is the case, use the section Power supply light comes on or flashes .
1. Disconnect everything from the PC, including the power cord.
2. With the power cord disconnected, press the power button on the front of the computer. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
3. Replace the power cord with another power cord, like the one used by the monitor.
Test to see if the computer can turn on. If not, continue using these steps.
4. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
5. With the power cord removed, flip the red voltage selector switch to the opposite position, wait about five seconds, and then switch the red voltage selector switch back to its original location.
This ensures that the voltage switch is engaged and set correctly for your country/region.
6. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
7. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
8. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
9. Use a vacuum cleaner to remove the build-up of dust from the power supply fan vent holes. Make sure that the PC is turned off and that the power cord is plugged into a grounded outlet. Only use the end of the vacuum hose near the outside of the fan entrance.
10. If all of the above steps have been tried and the power supply light remains off, use the steps in the next section, use the next section Power supply light comes on or flashes , to reseat the cables and check the power switch connector.
Jan 11, 2009 | Compaq Presario SR1000T (568657) PC...
Amber light instead of green light
160w is a very marginal power supply. Have you added any hardware recently? Anything you add draws more power. You can test the memory. Take one stick at a time out and see if there is any change. Better yet try some different memory. You might disconnect everything that is not essential for the computer to operate (CDROM, Floppy drive, sound card, network card etc. Try to boot with just the hard drive,memory, graphics card and motherboard plugged in. That is the minimum to run the unit. Your new graphics card is probably drawing more wattage also. If this 160w supply has not quit yet, it will, probably sooner than later so get a new one.
Dec 26, 2008 | Computers & Internet
Gateway MT6451 Does not turn on
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
Gateway (4000274) Motherboard Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
