Question about Siemens WTXD5300US Electric Dryer
Lint filter sensor cuts off machine within 5-10...
Filter is clean, ductwork clear. Have had "Factory Authorized" service on 3 occasions...they are clueless. Also had a service call from a non-authorized appliance repair company--more wasted money.
At this point, I prefer to disconnect the whole "lint checking" system and be done with this darn problem, as I thoughly clean lint filter each time dryer is used. The dryer has been useless for months, and it's getting too cold for a clothesline, especially in light of this unit's original cost!!
Thanks.
I await your reply.
  • 2 more comments
  • Shotgunthera Nov 26, 2008
    Checked sensor as suggested, same problem. Am not willing to continue with worthless technicians, nor pay (yet AGAIN) for service calls. A new control panel with installation will cost almost 80% of the cost of the unit.
    At this point...as before, I'm most interested in by-passing this little piece of junk, or over-riding it.
    If by exhaust line, you're refering to the flex vent/duct-work coming from the back, yes...I snaked it out all the way to the roof.
    At present, it is disconnected and the dryer vents directly into the room (basement). Could "no vent/duct cause a problem?
    Does this beast need to create or maintain a back-pressure...or vacuum?
    Any ideas as to how to rip this Lint Monster out by it's damned roots?
    I will never by another Bosch/Seimans product ever!
    I'm especially upset and disappointed because I've used/bought and swore by Bosch tools for over 20 years...best on the market, almost indestructible in commercial use--contruction business.
    NEVER again!
    I live in (Lovely) North Carolina. I belive the machine was assembled in the US.
    Would the serial numbers and such info from the name plate be of any help?
    Here is all nameplate info:
    Bosch/Seimans UltraSence.
    Model:WTXD5300US/01FD8501/30021
    (13595009).
    Ser. Number:8550\(or,the numeral 1)082971009216
    Type: WAT1
    240V~60Hz/22A
    Are you joking?? Did you read my earlier posts?
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Check this link let me know if it helped or not
Posted on Nov 26, 2008
  • Siemens Master
  • 4,806 Answers
Sometimes a lot of suds in tub will cause this cause lint and suds stick to the outer tub and is difficult to remove try filling the tub with hot water and use vinegar in the water half bottle let it stand for 5or 6 hrs .
Now drain the tub it should work.
regards
  • Lee Hodgson
    Lee Hodgson Nov 26, 2008
    sorry thought is was a washer/drier :)
    if the drier is just blowing cold air all the time and you have checked the sensors and outlet pipes, if all checks out well then the only thing it must be is the thermostat which is faulty and need looking at
    regards
    Sergeant:
    Champion:
  • 291 Answers
Tell me what is going on and i will see if i can help / has anyone replaced the sensor?
i dont know your dryer but some has a port on the air duct that gets stopped up and makes the sensor read wrong
  • Larry Youngblood
    Larry Youngblood Nov 26, 2008
    check on the air duct and see if there isn't a port stopped up with lent and if so remover and the sensor should work for you then / larry
  • Larry Youngblood
    biggest problem is that bosch dont give out any updates on their appliance ,,,,,, i have my own service for over 20 years ans with sears the last 10 and we just could not get updates from them but i will search and get back to you.
    Larry
  • 849 Answers
Dear consult to a authorized service center, they will give you perfect assistance.
good day
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suspect a location/condition mismatch to the sensor threshold of your lint filter. This specially would hold true if your dryer was intended for another region and was simply "regionalized" to conform to your country's electrical & safety requirements. Simply stated, the lint filter sensor should be replaced but not with the same specs. Should you wish to explore this notion, pls postback with your general location and an image of the dryer's name tag.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 26, 2008
    May I forward some thoughs:
    • the unit was intended for the European market (240V);
    • then the "Factory Authorized" service personnel would be following a checklist prepared for another country/region/condition;
    • if that were so, then certain particular settings in the control panel would be configured for European conditions, perhaps a little cooler temperature;
    • the sensors then would have a lower threshold.
    Since the lint sensor is basically as Ginko pointed out "temperature based", then it is most likely that it cuts off early. A few possible workaround would be:
    • improve the airflow over the lint filter/sensor;
    • replace the lint sensor with one for a little bit higher temperature;
    • would not suggest bypass the lint sensor, fire hazard;
    • ductwork should be as short as possible;
    • rigging an additional blower in addition to the original blower.
    But of course, your local electrical and fire safety codes should have first consideration. The above thoughts does not necessarily conform to factory repair procedures and more importantly are forwarded for evaluation purposes.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 306 Answers
Maybe the exhaust line is partially blocked. Have you cleaned the exhaust line lately..
  • Siemens Master
  • 19,396 Answers
Lint sensor is a temperature based sensor working on a thermic sensor, did they check the thermic sensor?
Posted on Nov 22, 2008
  • Ginko
    Ginko Nov 22, 2008
    remove the
    lint filter and use a flash light to inspect inside the duct. If
    it looks clogged you can try to clear it using your vacuum.
    If you still get the problem, the lint sensor is faulty and should be replaced.
  • Ginko
    Ginko Nov 22, 2008
    See a confront between users with same lint sensor problem , click here.
    You get all possible sollutions in that link carefully, pay particular attention to the last ones.
    If the lint sensor signal does not go away, then it is either a faulty control panel, or the dryer generating an eccessive temperature.
Check filter light blinking will not start only beeps what to do please help
Probably a lint buildup on the sensor. Need to clean the entire lint system. Should be able to remove the plastic frill if the lint filter is inside the drum. Remove the two screws and clean out all the lint then pull the dryer out remove the vent hose. Run a vacuum hose or reach up i to there and pull out the li t. Then clean out the vent hise...a broom handle works if it's a straight shot.
Oct 11, 2016 | Kenmore Dryers
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor · Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
The dryer stops
I would recommend you have someone take the dryer completely apart and clean the lint out. In the last 3 months, I have cleaned out 2 or 3 shoeboxes of lint from each of 5 machines.
This has nothing to do with the filter screen you are supposed to clean after every use.
It has to do with the lint that escapes the ductwork inside the machine itself.
You may be amazed how much you will find.
You will also need to check the ductwork from the back of your machine to the outside air. That pipe can also get clogged and cause the same results.
Be blessed.
Feb 13, 2014 | Kenmore Elite HE4 Electric Dryer
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Why do We have to dry clothes several times to get them dry?
It might just be time do do a little cleanup. No matter how good you are at cleaning the filter, lint is still gonna build in the dryer. themobilian_993.jpg
took the back dust cover off
While you are at it take the whole dang thang apart
speaking of a noise maker:
Go through it and do a good cleaning. No parts needed for that. then retry.
I have a service manual and more HERE
Jan 22, 2011 | Roper REX3614KW Electric Dryer
I have a whirlpool dryer (LER7646EQ2) that is heating but clothes take forever to dry and the lint trap appears to be trapping less lint
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 20, 2011 | Whirlpool Dryers
My dryer starts and runs but puts out little heat. To dry a load of towels I must run 3 or 4 cycles
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Nov 26, 2010 | Whirlpool Dryers
Dryer says check filter and it is clean
Air flow in the duct work is restricted... and the dryer sensor thinks that the filter is clogged.
You will need to take a fluffy cleaning wand and, with the filter removed, try loosening up some of the accumulated line in the duct.
Next, remove the lint pipe from the wall connector and try cleaning it and the pipe for as much distance as you can reach.
Finally, go outside and check the vent. It needs to be clean and clear of obstructions... also, needs to close when the machine is off.
You can do testing on the outside vent with "air dry" setting - hot air is not required... Keep cleaning ductwork until the outside vent passes air freely.
After air flow is restored, the sensor in the "VENT" alarm will act nice.....and stay off
Nov 01, 2009 | LG DLE2514 Electric Dryer
Lint filter sensor cuts off machine within 5-10 minutes.
It sounds like you might think you are sending this to Siemans? You aren't, Fixya is a self help website, people just like you helping others. Some of us are Experts on various subjects, like dryers.
Dryers need airflow and this lint filter just works out that either the temperature is getting too hot, or there is not enough airflow.
Trouble spots are usually the following;
Exhaust hoses too long.
Sharp bends on hoses.
Birds nests in hoses. Happened to me twice!
Wet lint build up as the hot wet air hits the first bend.
Plastic concertina hoses are really bad for air flow. Use the aluminium ones that are almost smooth.
Or my guess in your case, is vent flaps that are not opening fully or blocked. The whole external assembly with flaps and tube should be changed about every 5 years
Apr 24, 2017 | Siemens WTXD5300US Electric Dryer
Bosch gas dryer nexxt
lost ya on the chat window plz re do chat you wont be charged twice
Sep 05, 2008 | Bosch Dryers
Dryers Logo
98 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
