Question about RCA R52WH73 Projection Television
R52WH74 RCA
Hello sir, thank you for your help i am
walkerak1741 i am the one with the rca problem how about do you take the front off?
    Genius:
  • 1,011 Answers
It mean front panel or back side?
Posted on Nov 22, 2008
RCA R52WH74 HDTV started black outs for 10 -40 minutes
This is a repair by service techanician and can solve by first check for dry soldering, if found resolder , but if otherwise replace the z-sustain board and then check all the fuses again .
Thanks for asking...
Hope this will help out ..
Jun 04, 2010 | RCA Televison & Video
Is rca r52wh74 and rca d52w14 flyback interchangeable??
No you will need the 270125 Flyback for the R52WH74 as thats a ITC222A chassis. The D52W14 is the ITC222 and uses the 259296 flyback.they are not interchangeable
Jan 22, 2010 | Televison & Video
Menu screen keeps popping up cant turn it off RCA r52wh74
On your front panel board where you press on/off ch+ch- vol-vol+ the Menu contact switch is either dirty or defective,Clean all front contact swiches or replace them Clean with contact cleaner only for Parts Call Mats 1-800-628-1118 This another problem RCA has with these TVs.
Oct 05, 2009 | Televison & Video
RCA R52WH74 turns off 3 times
Hello Kira-chan,
You are going to have to take those capacitors out of the Tv and check them on a capacitance tester. Some digital multi-meters have them, but I would suggest using the LC102 by Sencore That way you can check the ESR, and the dielectric absorption of the capacitor. It is my suspicion that these caps are bad, but should be checked before replacing them.
In addition check the BLUE and RED CRTs for cracks around the neck oy the tube, BE CAREFUL.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Locating the ''flyback transformer '' on a rca mod #R52WH74
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
Mar 10, 2009 | RCA Televison & Video
Rca model r52wh74
You could get into service mode and set the convergence. The only problem is....RCA decided to remove it from the menu for the R52WH74. It only runs 1 time during the first setup, according to RCA Customer Service. This is the 2nd one I've bougt in 6 years. Enough RCA Garbage!
Dec 02, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
RCA R52WH73 Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
