Question about Zebra Stripe S600 Thermal Label Printer
Zebra S600 Printing Label Question
Hi:
We are trying to print a label where the data being sent to it, maybe have to print on to a 2nd label. Any time the data has to cross over to a 2nd or 3rd label, we can't get the label to print out at all. We are using Crystal to format the label.
Is there something with the printer itself where we need to ensure it's setup to Auto Feed so that it knows to continue on to a 2nd or 3rd label? Printing a label where the data fits on a single label, works fine. We are using Zebra S600 printer. Any ideas?
SOURCE: LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Posted on Nov 09, 2007
jigeo
  • 57 Answers
SOURCE: Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Posted on Apr 19, 2008
  • 10 Answers
SOURCE: Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Posted on Feb 17, 2009
  • 62 Answers
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Posted on Apr 18, 2009
  • 97 Answers
SOURCE: Zebra LP 2844 doesn't feed label all the way out
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
Posted on May 06, 2010
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Feb 10, 2012 | Zebra Stripe S600 Thermal Label Printer
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
The barcode cannot be printed on the direct label
Your description is not very specific but no printing can be the result of:
1. The darkness is not set high enough
2. The ribbon is loaded backwards
3. You are trying to do direct thermal printing (no ribbon) but the label stock is not direct thermal stock.
Maybe you can provide more details.
Hope this helps,
Jul 18, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 Printing
You have to program the tearoff.
See the manual or use a windows driver to end the value to your printer
Aug 24, 2009 | Office Equipment & Supplies
Zebra printer 140xilll - Too many print jobs?
It does sound like you have a memory overload when you send the 2nd print job. Each label is getting sent to the printer and filling up the memory. Make sure you are using the printer resident fonts and not a regular windows font. The windows fonts get sent down as graphics and take up memory. What zebra is saying to do is store the format of the label in the printer memory and then just send down the information that changes. For example if you were printing a UPS label the basic format of the label is the same but things such as the addresses and tracking # would change.
Jun 23, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Not printing the correct text / picture
Hi..
Try using used generic text printer driver instead of windows driver for that model.or in the SAP environment try to used other driver..
Sep 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Labels print out of position
Try cleaning the media and ribbon sensor you can open it and try clean it, it possible that there's a lot of dust or even small particles at the sensor path..
Jun 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Printing fade at the midle of the page
Build up on the printhead, printhead pressure, or worn platen roller...
Apr 26, 2007 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
78 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
