Unit is running in pump out mode
SOURCE: bosch 5315 dishwasher
You can try tripping circuit breaker OFF, then ON, Can't hurt.
Check manual for reset procedure like hold down Normal wash and Delicate/econo wash at same time and push POWER ON.
Manual for 5300 series may be on line at bosch.com
SOURCE: Runs with door open and pump continues even when dry.
so what is the problem?
tell the problem clearly
SOURCE: Bosch SHX46A (6 years old) Selected
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump. It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck! Please report back what you find, OK?
SOURCE: My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
SOURCE: Will not fill. Drain pump runs all the time.
Sounds like flood switch has been activated. They have a float in the base of machine, which will activate drain pump if a leak has occurred. Unplug from power- remove right hand side panel, check to see if any water in base. If so, leak has occurred. Clear water from base and test run to locate leak
