Question about Samsung HCM553W 55" Rear Projection Television
Picture out of focus
My tv was fine Samsung 1080i model now it's all out of focus and looks like inverted horse shoe big on edges and narrows to the middle? have no idea what happened it was working fine. perfect focus says No Sensor data?
  • brunovaz76 Apr 25, 2009
    good morning!
    (samusung sp477w3hf1x)
    tv is the image of effort, because the colors appear purple and yellow! what will? already told me what could be the block of devergencia! this is the problem?
    I await a help, thanks!
    Problem Solver:
  • 5 Answers
There will be two big Audio Amplifiers on the convergence board, they will say STK382 or some such STK number on them. Look for burned connections on the bottom of them and resolder any suspect connections before anything else. If that doesn't work, get an ohm meter across the various outputs and look for one of them with vastly different readings than the others and change the chip with the funky readings. Lastly look for the connection to the edge sensors on the sides of the screen about half way up. If that wire is disconnected it will give a very bad picture that is very similar to what you are describing.
Posted on Dec 10, 2009
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
I cannot see football stats on bottom of screen. mitsubishi wd-62627 setting is hdmi 1080i standard. help!
either your TV or your cable/sat box(if any) is on zoom(enlarging pix). Look for buttons on both remotes that might say picture size or aspect something like that...Pressing these buttons usually cycle thru 3 or 4 size options. When in zoom center of screen is the focus and outer edges of pic are cut off.
Sep 11, 2010 | Mitsubishi WD62627 62" HDTV
Tv not switching on
Hello Fixya customer,
Thank you for your question.
There are several possibilities here, including the power supply, back light inverter, and signal source.
Have you tried both the remote and manual button?
What sources are you using and how are they connected to the TV?
To narrow down the possibilities for your specific model, please send me the model number.
Thank you for using Fixya, and I look forward to your response.
Apr 30, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
Jun 04, 2008 | Televison & Video
Samsung 1080i
ic chips are no good if u can open it up get fan on it blow dust out for super bowl keep it cold
Feb 03, 2008 | Televison & Video
Inputs
learn lip reading..... but really 1080i inputs have to cut main circuit and be processed through your main amplifier .
shorted or too low a signal at input is a start.
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hdtv 1080i
Whats the model number of your set? Need that info also let me know does the picture appear almost 3D?
Aug 28, 2007 | Sony KP-53S65 53" Rear Projection...
No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
May 21, 2007 | Mitsubishi WS-73411 73" Rear Projection...
Wierd problem
HD projection televisions have seperate convergence alignment for 480i-1080i thus your problem when you use your XBOX360. The "No sensor data" that shows up is due to the fact that the sensors need to be initilized after doing the convergence in 1080i mode. You will probably need a technician to do the alignment because if it is out that much then a template needs to be used to get it corrected. For now you can put your XBOX in a lower display mode until repairs are done.
Jan 30, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCM553W 55" Rear Projection Television Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
