Question about Eastern Tabletop 7002 Stainless Steel 24 Quart Ice Cream Maker
Magic chef MCIM30TS table top ice maker shovel breaks
Our magic chef table top ice maker went strong for 2.5 years. Then inexplicably the plastic pin holding the sweep ice shovel blade broke. We purchased a replacement shovel and installed it only to have it break again. This time the shovel blade broke at one of the arms attaching it to the sweep mechanism and after only two weeks of use. Ordered a second replacement. That one broke after three months of use and in the same arm! Part is not under any warranty so I will have to purchase a new one from somewhere. I suspect that something is not aligned properly or that the replacement is not correct. Any solutions (short of purchasing a new ice maker).
  • 2 more comments
  • tazjohnson Dec 09, 2008
    I have the same problem with a broken shovel plastic arm pin but have not replaced the shovel yet. This is the pin that attaches to the arm that is attached to the water tray.
    Very small plastic pin only approx. 2mm in diameter.
  • bakerfamily7 Jan 08, 2009
    Our shovel just broke on our ice maker, how did you replace yours? did you have to take the top off? Thanks
  • paul woolman Jan 12, 2009
    The first time it broke, I took it totally apart and superglued the plastic piece back on....it worked for about 3 months. Now I need a new one again because the next time I take it apart, I want a new piece bacause it took me all night to take it apart and reassemble it.
  • Anonymous May 14, 2009
    I like to have a shovel parts number,so i can order it ! because i dont have a manual instruction book ! I have the same problem !
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Posted on Mar 20, 2010
I need to order aice shovel for my magic chef tabletop icemaker model #MCIM30TW
try this page - I have a similar model (MCIM30TS) - however, I can't figure out how to remove the pins to remove and replace the ice shovel...any ideas?
http://www.repairclinic.com/Shop-For-Parts?searchText=mcim30ts&Search=Find%20Parts
In case the link does not work properly, just go to the repairclinic.com website and enter your model number in the search box...
hope this helps
- Margaret
Sep 15, 2010 | Eastern Tabletop 7002 Stainless Steel 24...
GELATO CHEF 2000
I was telling the problem over the Convenience Store when another customer said she would lend the 'Instructions'! She has a Chef 2000 (not a 2200).
Nov 27, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Need instruction or manual for the Magic chef ice maker model
Hope this helps. This is the link where you may be able to download
http://www.partselect.ca/Search-Suggestions.aspx?term=MCIM30TW
Nov 22, 2009 | Magic Ice Cream Makers
Magimix Ice cream maker - Le Glacier - lost instruction book
Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support. Manual for ice cream maker ... Need Instructions/User Manual. Magic chef ice maker model MCIM30TW ... fixya.com/support/p519941-magimix_2200_gelato_chef_1_03_quart_ice/rss
best regards mike
Aug 17, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
have you checked on the fuse and the thermostat of the appliance, because aside from the cooling system, you may want to check on the easy parts first.
i will go further on this, will keep you updated if in case i find more.
Aug 11, 2008 | Ice Cream Makers
Danby icemaker not pumping water
I have the same problem, the ice shovel was catching and not moving forward to shovel the ice, this stopped the ice maker. i have cleaned off the surplus plastic from the molding process (on the underside of the shovel) and this so far has cued the problem.
Jul 16, 2008 | Ice Cream Makers
When the paddle on my machine has stopped rotating it shoots the motor and guard off the top
you are letting the ice cream get to frozen, this should be a soft gelato ice cream, after 20 minutes turn off the top motor a leave on with the freezer unit still working or take out mixture put in tubs and put in freezer, the lid is designed to come off to stop the machine from breaking. Any magimix parts can be bought at http://www.magimix-spares.co.uk/
Feb 20, 2008 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
When the paddle stops rotating the motor shoots off the top of the machine
you are letting the icecream get to hard , this is a soft gelato ice cream , you must turn off the top motor and leave the freezer unit going after 20 minutes. for all spare ice cream parts go to http://www.magimix-spares.co.uk/
Open Questions:
Eastern Tabletop 7002 Stainless Steel 24 Quart Ice Cream Maker Logo
1,149 people viewed this question
Top Eastern Tabletop Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you an Eastern Tabletop Ice Cream Maker Expert? Answer questions, earn points and help others
