Question about SanDisk Sansa e250 MP3 Player
I have a sansa e200r something is wrong
My e200r was working for a while now i tried to turn it on the ring glows but the screen doesnt turn on how do i fix it?
I had the same problem, hold down the power button for 30 seconds (even if it turns off in the meantime) then let it sit for a bit. Everything should be find after that.
Posted on Jan 11, 2007
Take the back off and take the abttery off and then replace the battery and that should fix it chief. -The Master
Posted on Dec 28, 2006
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
Sansa E200R gets stuck in refresh when I turn it on
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Deleting videos off Sansa e200R
There is no such thing as a stupid question. Plug Sansa as you normally do. Go to My Computer, and click on the removable drive that holds your Sansa's data. If you don't see the video folder that means it's invisible. To make your invisible folder visible click on Tools on the top of your window. From there select Folder Options... A new window should open up and click on the View tab on new window. Look for Hidden Files and Folders on this list and select Show Hidden Files and Folders. You should be able to see your Video folder now, and the rest is up to you. Good Luck!!!
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
Black screen blue ring
Try holding the Menu button for about 15 seconds.
Apr 01, 2007 | SanDisk Sansa e260 MP3 Player
i just had the same problem try opening the mp3 player and removing the battery, then put battery back in and it should start working again
Mar 10, 2007 | SanDisk Sansa e260 MP3 Player
Player hangs at initialization screen
I'm returning my 3rd one today for the same problem....will not get another one of these!!
Jan 05, 2007 | SanDisk Sansa m240 MP3 Player
Sansa e200r
my Sansa M200 has a frozen screen, tried removing battery but comes back screen frozen
Jan 04, 2007 | SanDisk Sansa e200 MP3 Player
Help! my sansa wont turn on.. but the blue ring is still glowing
My sansa 260 has had the blue ring glowing and no screen for a while and I tried all the repair software and none of it worked because my sansa would not connect to my computer. I used the 15 second trick to turn it off, put it on hold then opened the back. Above the battery in the back is a black rectangle which was out a little so I pushed it back in took the battery out and put it back in and when i closed it and turned it on the screen was back! Works perfectly now
Dec 30, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
