Question about HP LaserJet 5si Printer
I have a HP laserjet 5si with error 79 Service (65ff)
5 Suggested Answers
  • 81 Answers
SOURCE: HP LASERJET M1522 NF 79 error what is it?
The unit has encountered an internal firmware error. If it's plugged in to a surge protected extension lead then remove it and plug it directly in to the wall socket. Retry the printer. If this fails again, then it looks like it would have to be a formatter replacement on the printer
Posted on Oct 13, 2009
  • 24 Answers
SOURCE: HP LaserJet 3200se 79 service error 694:SM.C
1st shut the printer off
2nd Disconnect it from the Computer
3rd turn it on
Does the error still occur?
If it starts properly print a configuration page.
If this is possible you have a Printer Driver issue.
Replace the Print Driver.
If it still has the error when the printer is NOT connected to the Computer then you have a firmware issue most likely.
Posted on Nov 06, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
HP LaserJet M425dn MFP 79 Service Error
How To Troubleshoot HP 79 Error?
This is a fairly found as a common HP printers error which is usually caused by malformed PostScript documents in the HP printer. According to the study by a HP error 79 technical support professional team experts, printer shows a "79 Service Error" on the LCD display. HP service error 79 is a considered as a quite generic issue which is found on the HP LaserJet printer while working. Most of us face this same issue unexpectedly. But there are ways to get over with it:
What you need to have?
- Internet access.
-Admin account for the computers
Steps to resolve this HP error code 79
    ?In the very first step, you are needed to switch on the LaserJet Pro 400 printer.
    ?Ensure that the printer is properly connected to the internet. Users should be able to have a strong
    ?Ethernet cable connection running from the device to their modem or may even require to switch or a router.
    ?Now in the M401dn control panel/display section, click on the "Network" icon first.
    ?As per as study by HP error 79 tech support is concerned by a HP error 79 tech support technicians, verification of the IP address on the printer machine is necessary. Well, if it shows 192.168., then it clearly signifies that you are well connected to your home network. Else, a small check is needed to receive a symbol like 169.....
    ?Now step back to the home display section and then click on the "Settings" icon.
    ?Choose an updated LaserJet printer and then perform a check for all the firmware updates to ensure about all the latest updates.
    ?Continue the process by choosing a proper update and then click on the download and install button
    Fix your HP issues anytime with our HP professionals
    We deliver the best-in-class HP customer support service solutions for HP users across the world equipped with top-notch HP printer support solutions by applying the latest technologies to match users' need. Our HP printer support Toll-free 1-800-213-8289 number is all-time accessible for users across the world at our toll-free calling contact details to fix various critical types of HP printer problems affecting the performance of your HP printer. Prices are extremely feasible in nature.
Sep 16, 2013 | HP LaserJet Pro 400 MFP M425dn
79 error in hp laserjet 3050 all in one printer
Turn off the printer wait 2 minutes, then switch on check. up date firmware, replace formatter assm.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
My hp Laserjet 3330 Had error 79
Firmware error. Unplug the power cord. Wait 30 seconds. Plug it in, power it on. If the error comes back, you will have to upgrade the firmware.
May 20, 2010 | HP LaserJet 3330 All-In-One Printer
57 service error message. Wht does that mean? We
A fan failure was detected.Printer fan or Duplex fan.
1. Check the fan’s connector and make sure the fan is not blocked.
2. Replace the fan.
On older style printers this is often caused by a bad main motor. (Older style printer being printers with halogen heating elements in the fuser - 4, 4+, 5, 4si, 5si, etc).
Oct 19, 2009 | HP LaserJet 4 plus Printer
My hp laserjet 3030 keeps reading 79 error power on power off
79 errors are often fatal. Your only hope is to get it back to READY, then update the firmware before it reverts back to 79 ERROR. The other option is to replace the formatter, but it would be about the same cost to replace the whole machine.
Apr 07, 2009 | HP LaserJet 3030 All-In-One Printer
Have error code says 79 service(0142) Trap:00 Adr:0018D3F4
Turn off
Remove printer cable or
If it has a network card remove it
Turn printer back on
Let it come to Ready
turn off
re-install all cables / network card.
Jan 27, 2009 | HP LaserJet 5si Printer
3rd turn it on
Nov 06, 2008 | HP LaserJet 3200se Printer
Hp laser jet 5si
Can you be more specific in the problem?
Also, please specify "how" you are connecting to the printer (parallel, LAN, etc)
Nov 30, 2007 | HP LaserJet 5si Printer
HP LaserJet 5si Printer Logo
334 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
