Question about Car Audio & Video
Mtx blue thunder 752 pro
My anp works fine. but when i bridge it. it seems to melt the fuse and cuts out
  • dmanuel703 Nov 21, 2008
    myn does the same you fuckin ****
    Scholar:
  • 130 Answers
When you bridge amp they some time double in power output into a certain load. If the actual load of your speakers are lower than the required bridged load the out put of the amp will proportionally try to increase again. You have to match your loads to the specs of your amp. Use your manual to see what is required, then use ohms law, for adding resistors in series/parallel to make your speaker load match. For more info please reply.
Posted on Nov 22, 2008
How do I Bridge MTX Thunder 404 400 watts into one channel
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Nov 25, 2016 | MTX Car Audio & Video
Hello,I have a 2001 gsxr 600 and it was just running fine,I came out from eatting and it wouldn't make a sound! All guages light up fine,fuel pumps engaging,in neutral,push the start button and nothing!!!...
there is a fuse in the starter solenoid, check it, also try to bridge the two battery posts, to see if starter works and starts. turn off, check if bridging solenoid signal and battery pos actuates starter solenoid, if solenoid seems OK, check disasembly of starter switch, if bridging starter switch wires acuate solenoid, this will indicate if switch or wiring is responsible.
Aug 03, 2014 | Motorcycles
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
JL Audio Amp. My amp all of the sudden started cutting in and out. It's an older amp and I've never had issues with it before. I've checked all the wiring and the fuse it all seems fine. Any...
you need to determine what impedance the amp is running at ,how many spekers ,most 2 channel amps will only run 2 4 ohm subs per channel and only 1 4 ohm speaker in bridge ,Basically if you have 2 4 ohm speakers bridged at the amp it will usually cut in and out .Some amps will not do this for a while and will work for a while at low impedance but once they get older and hot and cool off many times they will then only work for the intended ohm load ,Do you have 2 speakers ,if so make sure 1 is on left channel and 1 is on 2nd channel (should not cut off ) if it is a mono amp ,make sure you are only running 2 4 ohm subs and not dvc speakers (these will run 1 ohm and shut the amp down ) there are ways of wiring more speakers or dvc speakers ,I can explain but I need to know what product you have .
May 07, 2012 | Car Audio & Video
Why does my MTX thunder 702x amplifier cut on and off
Check fuse on amp under hood. Also, check wire connections makes none of them are loose and move your RCA jacks around to see if you have a short.
Jan 04, 2012 | MTX X Thunder 702X Car Audio Amplifier
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
I installed my amp into my 02 neon and it just drains the battery, even while amp is off.. while driving even the amp makes al te lights dimand flicker. i unhooked the power supply for the amp and now the...
Your amp is straining for power, try upgrading your alternator or and a battery in your trunk... or capacitor.And also make sure that the fuse closest to your amp is the total value of the fuses in your anp
Aug 02, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
I have a mtx thunder 81000d amp i need to know if i can bridge it
Hello frank_sadach,
"Bridging" connects 2 amp channels to one output. The MTX 81000d is a single channel amp so it cannot be bridged.
Hope this helps.
Oct 23, 2009 | Car Audio & Video
Car Audio & Video Logo
564 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
