Question about McCulloch Garden
Fuel leak I have a 2.0 mccullogh chain saw thats leak out gas as soon as you fill the tank.
  • 211 Answers
Hi jaspunkin
check the fuel line,tubes and the integrity of the fuel tank,
regards savumihai71
Posted on Nov 29, 2008
Chain saw motor is smoking
Hi Mark:
I'll go over the basics so please ignore what you already know.
Chain saws are 2 cycle which means the gas must have oil added. The ratio is 50:1 typically.
Chain saws are air cooled so they get HOT. They like to be kept clean, and a build up of oily sawdust is an invitation to an unwanted fire.
The chain is lubricated by a thick oil that gets put in a different tank. If you run out of chain oil, the chain will get really hot and you can actually ruin the bar by overheating it. A good rule is to always fill the chain oil tank (with chain oil) at the same time that you fill the fuel tank (with gas/oil mix)
Make sure the chain is kept SHARP. A blunt chain makes the saw work harder and causes friction which generates heat.
On a regular basis, take the bar off and clean the brake assembly and all the bits and crannies. Compressed air and solvent will make the job easy.
Chain tension should be kept snug but not too tight. I like to be able to lift the chain at the centre of the bar and have the underside just barely clear the groove in the bar.
Lots of bars have a roller at the tip and there is a fitting to inject grease. It's a good idea to use it regularly.
I think that about covers it. If you have any specific questions, send 'em on.
Apr 30, 2015 | Garden
How do i serviced the fuel system on the OZPCS305A chain saw
first check for split in Primer bowl.
Check to see if Heaver fuel filter in the tank broke off the end of the gas line. That's typical with this horrid Ethanol Gas.
Dec 16, 2014 | Garden
Lost my manual for my Poulan wild thing 2375 chainsaw and I want to fill it up with oil and fuel.
Fill the oil tank at the front of the saw with a non fling chain oil, or as thick an oil as you can get, fill the fuel tank with a 25-1 fuel oil mix, use a good, well known brand of two stroke oil designed to be used in chainsaws.
Jul 15, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The saw is a poulan 3416 ,2 yr old, purchased new. the problem is starts ok 6 primer pushes idles ok then will either die after first cut or as soon as you pull trigger
Run too lean, this is fuel starvation, remove the fuel line from the tank and replace the filter on the end, check the fuel hose from the tank up to the carb for leaking or cracking.
May 14, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I filled my 340 husqvarna chainsaw for the first time this year and it leaked gas from someshere opposite the fuel fill tank( maybe near the fuel line). It then quit leaking and just will not start. Maybe...
Opposite the fuel fill is the tank breather, and the return to tank hose if the machine has a primer, the back to tank hose fits on to an orange connection in the tank, it may have slipped off, next to it is the breather the early breather was two white pellets pressed into the tank, these will need to be removed and replaced if this is where the leak is from, the later breather is a white round assembly with a connection on the top, nothing fits to this conection, the breather can be pulled and and replaced if required.
May 01, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a 345 e Series 18" (I think it's 18). It's a couple of years old and probably no more than 3-5 total hours usage. Normally starts and runs perfect. Today it won't run, seems to be starving for gas....
If stale fuel has been left in the saw then try draining the tank and re filling with fresh fuel, also hook the fuel line out of the fuel tank and replace the filter on the end.
Apr 15, 2017 | Husqvarna 18" 502cc Prosumer Chain Saw ...
My Poulan Pro 260 chainsaw will start and run when the choke is pulled out, but as soon as I disengage the choke, the saw dies. Do I need to have the carbuerator checked?
It is running in a lean condition. Continued operation like that can cause piston and cylinder failure.
I'd take it in for repair estimate ($10) at the local chainsaw seller/mechanic. Explain the problem you are having, Probably a leaking fuel line. I'd expect a repair and tune up about $40-60. Your saw will perform better and your arm will thank you. If tuned ask what fuel/oil ratio they used (should be 50:1) and affix a label to your fuel tank. HTH
Lou
Nov 08, 2009 | Poulan Pro Chain Saw 46cc 20"
Cant figure out where fuel lines go on mccullogh chain saw
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Jul 01, 2009 | McCulloch 26cc Gas Blower Mcb3208
Chain saw wont start after running out of gas?
Hi
Fill the gas tank with new fuel.Priming the engine(put some gas in the sparkplug hole for few times and start the engine until it runs constantly):There is small amount of water in the gas.
best regards savumihai71
Dec 27, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
159 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
