My printer does not work its a hp officejet v40xi
  • 1 more comment
  • smith9981 Nov 21, 2008
    The printer icon has a black circle with a check mark in it next to it, what does this mean? Also when I go into the printer ports there are 8 showing. Can I safely delete all but 1, also how do I clear all of hp and start over?
  • smith9981 Nov 25, 2008
    I`M TOLD TO MAKE SURE i HAVE THE RIGHT DRIVER,what does the black circle with the check mark in it mean?When I select print it takes the order but does nothing, Also I have more than one driver listed should I delete all but theone that says v40xi hp ?
    I followed the last advise, printer sends message to the Q and it stops there
    Genius:
  • 1,268 Answers
The circle with black check means "Default Printer" or "Active Printer" driver. With regard to your problem, you can restart your computer first. After that, do the following:
1. Go to Control Panel > Printers and Faxes
2. Right-click the printer icon with black check > Properties
3. Go to Ports tab and check the box USB Virtual Port.
4. Click OK all the way out.
Turn off printer for about 3-5 minutes, unplug the USB cable then after 5 mins, plug the USB cable, power on printer and try to print.
Posted on Nov 25, 2008
    President:
  • 1,901 Answers
First thing I need to know is what operating system you are using. That will be the first thing in determining a solution. I did not see it mentioned in any of the comments.
    Sergeant:
  • 207 Answers
Smith,
The black circle with the check means that this printer is set as the "Default" printer. Basically that unless you specify a different one all print tasks will be handled by this one.
OK lets see if you NEED new drivers.
Open the devive manager page Push <Windows> and <Pause/break> keys at the same time. Then select "Device manager" / "Hardware" depending on which version of windows you have.
Once in device manager look for the listing for "Printers"
Is your Printer listed in here?
Is there a little yellow marker with an ! in it?
If you answered No to the first question or yes to the second question you need new drivers.
If you have the driver and it has an error marker on it, right click it and select uninstall (This will get rid of the corrupted driver)
Now we need to get some new drivers for you. Click the link below and select YOUR operating system from the list and you will be taken to the download page for your printer.
There are drivers and software in the list. You will NEED the drivers and if you have the room I would recommend the software.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=60631&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20»
download and install the drivers and if you got it the software.
Reboot the system and then try to print something.
If that does the trick for you, then we've found your problem.
If not please post your results here and I will try to resolve this for you
Thanks
Dave
  • 1,879 Answers
You got the right driver as it shows your printer model in Printer & Faxes.
Computer-Printer communication is what you have OR the Windows Print Spooler.
Cancel all documents in the queue than delete all instances of the printer icon in the Printers & Faxes window (it's only an icon, the driver is very well hidden in Windows system folder)
Disconnect the printer, Reboot the computer.
Once computer is ready, re-connect the USB cable, Windows will automatically create a new printer icon for you IF you got good connection.
  • 162 Answers
Printjob stays in the queue ?
If the printer is connected via USB cable:
check device manager to verify computer-printer connectivity (right-click my computer icon and choose properties. then click the hardware tab and click the device manager button), scroll down and expand the USB ceontrollers section. it will show as "USB Printing Support" . if it doesn't show up, change USB cable and try other USB ports.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls follow below procedures:
  • power off the printer and disconnect all attachments (USB & power);
  • on the computer, goto Start, Printers & Faxes and delete all instances of your printer;
  • Reboot and verify that there are no longer any installed/left over;
  • download, install and run RegClean;
  • Reboot;
  • Do not connect the printer. Insert the CD installer and re-install the drivers;
  • connect and power up the printer only when requires and prompted by an onscreen instruction;
  • you may need to reboot.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Guru:
  • 859 Answers
Wow. You need some real help here. Are you ready? You've been left out in the cold with no real help.
Look on the back of your printer. There is a model label back there that is specific to the actual internal name and not the branded name on the front. Send the model number from the back and post it here.
I'll work with you until you're fixed. And, honestly I've never experienced a black circle with a check in it. I do not know what that means. OK? Maybe we'll both find out together. But, I don't think it is a good sign.
Regards,
Worldvet
    Genius:
  • 3,422 Answers
HI,
Please make sure you have installed the right drivers for your operating system.If you have any hardware issues like printer not turning on then please unplug all the cords of the printer and plug the cords back in after 10min.Make sure they are plugged in tightly.
Posted on Nov 21, 2008
    Sergeant:
  • 276 Answers
First check the power cord it must be faulty.try replacing the power cord.
  • smarttech Nov 21, 2008
    if there is proper power getting to the printer and the power led is coming ON properly
    and u r nat able to connect it to the pc try this option
    Drivers, Software, lost C.D....come this way!
    If you have lost you cd or don't know how to install your printer then all you
    need to do is download the drivers and software from the manufactures website
    that suits your operating system and printer.
    Drivers and software download areas for brands listed below, just click to gain
    access and then locate driver for your needs.
    Brother Epson Sharp
    Canon Lexmark
    OKI Dell HP Kyocera Samsung Konica/Minolta
    Xerox Panasonic
    PLEASE NOTE
    When installing drivers/software it is generally a good practice to -
    Delete
    old/previous installs
    Leave printers
    USB cable disconnected from computer until newly installed software requests it
    to be connected.
Will my HP Officejet v40xi All-in-One Printer work with my new macbook?
This printer is not supported by HP under Mac OSX. You may be able to get it to print with limited functionality suing a generic driver, but none of the specialized functions such as scanning will work.
However, installing an emulater program such as VMWare or Parallels will allow you to run Windows on your Macbook. You could then download the driver from HP's website here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=28235&lang=en&cc=us&prodTypeId=18972&prodSeriesId=28234&taskId=135
and use the printer from within Windows.
I hope this helps!
Mar 02, 2011 | HP OfficeJet V40xi InkJet Printer
Install HP Officejet V40Xi on Vista , need a driver?
Windows vista has the driver built in as described here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=us&product=60631&lang=en
Please rate answer if it helped ,if not then let us know
Thanks
Oct 21, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Hp v40xi printer
i assume you have installed the original cartridge, in this case you may need to reinstall the ink once again, the head contains a small chip that recognize the presence of the new ink, unless you are using a generic one which can also cause this issue
Sep 14, 2009 | HP OfficeJet V40xi InkJet Printer
Cannot get scanner to operate
If its connected to the computer and you are tring to scan it there you might have to see if there are any updates to the driver software or you might just be missing the one for the scanner part of it.
Jun 30, 2009 | HP OfficeJet V40xi InkJet Printer
Can I operate my HP v40xi without a color cartridge?
I would like to inform you that there is no way to print with black cartridge alone. You need to install two cartridges to wok the printer. So I recommend you to install color cartridge and change the settings to print in black only.
May 22, 2009 | HP OfficeJet V40xi InkJet Printer
I have an hp v40xi. I recently changed my home number and can't remember how to replace my old phone number with the new, in order to get my fax to work.
The FAX header information can be changed using the HP software or the front panel on the printer. Instructions can be found here on the HP website.
Changing your phone number should not affect the fax operation. Are you sure that was all that was changed?
Jan 07, 2009 | HP OfficeJet V40xi InkJet Printer
New computer
Go to www.hp.com and let the website auto-detect your printer and download the drivers, however, this is pretty old printer.
Good luck.
Printing
The printer hp officejet v40xi is asking for a cartridge alignment. When I press enter the printer does nothing want take paper or engage the paper nothing
Aug 12, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Scanner portion
The easiest thing to do is a system restore; it will restore all of your computers settings to a point before the software was changed. Go to start, programs, accessories, system tools, system restore.
Folow the onscreen prompts and select a day prior to the day the scanner stopped working. It will reboot, then restore. Then your computer should be just like it was.
Jul 03, 2008 | HP OfficeJet V40xi InkJet Printer
Hp officejet v40xi for Macbook pro
see my link and goto hp and download driver to suit if supported and dont bother cause I just checked and it is not support on macs see specs that state same.
Dec 22, 2007 | HP OfficeJet V40xi InkJet Printer
211 people viewed this question
k24674
