Question about Hyundai Q321 32 in. LCD Television
No picture,buzzing, no hope?
I've owned this q321 for about 5 months and just now it gave out on me. I turned it off and it began to buzz (a screechy kind of buzz. The buzz stopped after about 3 seconds. Ever since this happened there has been no picture and that damn screeching buzz is sure to start every time i turn the damn thing on. My assumption is that maybe dust got into it and a circuit fried or something but i dont know. Is there perhaps anything I can do to fix this in order to avoid dealing with the hassle of the warranty?
    Problem Solver:
  • 6 Answers
It sounds like a problem with flyback transformer ,horizontal output transistor,deflection Yoke shorted ;these things could of caused another problem with power supply transistors/ic's shorting out. A professional technician is required to diagnose this serious problem. Technician: Tim Rasch
Posted on May 23, 2007
  • john811c Feb 05, 2011
    LCD TVs have no flyback transformers the do have individual transformers for the back light tubes , they have no defection yokes as they are not cathode ray tubes CRT and do not need one horizontal output transistors, probably not the screen is controlled digitally so probably have a microprocessor to control that. The Key word here is LCD not CRT. a side note these TV's were notorious for bad power supply boards due to defective Electrolytic capacitors installed on them. the simple fix would be to look at those and replace them all in the power supply board as well as on the HV backlight board. Or if your not comfortable with a soldering iron replace the power supply board first.
I have the same TV. The screen went dead. Turned on the tv and waited for a few minuites for the picture to come on, the light went out. the tv is dead. I am dealing with Hyundai to have it repaired. You have to file a claim on the web site. They contacted me and I had to send them a picture of the Tv. I am waiting for there reply. I had the same problem with a TV i bought my mother. It is a Hisense. I am dealing with them, long time getting back to me. Both tv's sound like they have the same problems, power supply.
Posted on Feb 13, 2007
SOURCE:
My Plantronics Voyager Legend has a constant buzzing noise, it does not work at all. When I turn it off or on, it does not matter, just a buzzing noise.
I just had this happen to me. Like yours mine just kept buzzing and the on and off switch had no effect. It just kept buzzing.
The way I was able to fix it was to reset the device by holding both the mute button and the call pick up button until the buzzing stopped. It took only 3 seconds to fix and it immediately began to work. When I switched it on the buzzing was gone and it was working again.
I hope this helps anyone as I didn't see and answer to this issue online anywhere and had to figure it out myself. Take care.
Mar 18, 2013 | Plantronics Voyager Legend
We Have a GE Model JVM 3670BF001 Spacemaker that started making a buzzing noise periodically when turned on. After a few times of buzzing it quit heating.
You probably had a bad connection now with pop probably separated. You may also have a bad thermal over heat device. one brand is Thermodisk. But you need to know what you are doing. Might be time to replace.
Oct 18, 2012 | General Electric JVM3670BF GE Profile 36"...
My speakers just out of the blue began to buzz in the middle of a song. The volume was low & did not seem to effect the buzzing - after I turned music off speakers began to make a high pitched ringing...
I've never worked on this model so I can't give you a definite part value or location, but you'll probably find a bad filter capacitor (or possibly more than one) in the power supply. The power supply converts the AC power line voltage to the DC (direct current) needed by the electronics. If the filter capcitors don't work, the result isn't smooth and steady, and the result is an annoying hum. You're probably hearing this.
It's possible to replace the bad capacitors, but it's not always easy. The people who make computer speakers don't often design them to be serviced, and sometimes it's a challenge getting into the power supply. But if you or someone you know with some electronic soldering skills is willing to give it a try, you might be able to bring these speakers back to normal. Good luck and thanks for using Fixya!
Jun 01, 2011 | Dell Ay410
My laptop speaker won't stop buzzing. It began
A buzzing/humm sound could be a earth loop problem. This is caused by connecting amp equipment into different mains power outlets.
Use a power board and connect all your amps and laptop to the one power board.
Nov 08, 2009 | HP Pavilion dv9000z Notebook
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 13, 2009 | Olympus FE-230 Digital Camera
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Hyundai Q321 32 in. LCD Television Logo
270 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Jaime Hernandez
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
