Question about Microwave Ovens
Sharp R-1514F Microwave problem
When the start button is pushed the light comes on and the counter comes on, however, the plate inside doesn't spin and the fan does'nt come on.
  • Microwave Ovens Master
  • 9,098 Answers
Your lower door switch is bad or its mount is broken.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
We have a similar service manual that works for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
If you only need a switch, you can order a universal type from us for $5 postpaid.
The best place to order other Sharp parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 24, 2008
I have a sharp microwave/convection oven model# R-9H84B. I bent/broke the left door latch after hitting it with my elbow when the door was open. I could bend the broken piece back in place enough to shut...
Sharp calls the hooklike parts protruding from the door "latch heads", and curiously they call the switch holders they plug into "door hooks".
Makes no sense to me, but that's what they do. :)
I would say the bent latch head needs to be replaced.
The part numbers for the latch heads are LSTPPA134WRF0 and LSTPPA135WRF0 but the part list on Encompass' Web site does not say which is which, and I do not have the service manual.
So it's probably best to call and ask them when you order. Or just order them both.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Aug 06, 2013 | Microwave Ovens
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Removing sharp R1831 over the counter convection microwave
the two long rectangular rod should slide down 1" to 1.5" unlocks the back plate and then it will slide forward and come off the wall.. hope it helps
Sep 19, 2009 | Microwave Ovens
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
Jun 01, 2009 | Sharp R-1870 Convection/Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Cooking
I would say the high voltage diode blew.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can get Sharp parts from Tritronics at http://www.wehaveparts.com
If it's not the high voltage diode, reply back for further help.
Oct 24, 2007 | Sharp R-1610 Microwave Oven
Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Sharp R-9H66 Microwave Oven
Microwave Ovens Logo
182 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
