Question about Toshiba Satellite A100-S8111TD Notebook
Satelite laptop (toshiba)
Hi my laptop isnt going that well when i turn my laptop on the starts to say insert system disk into drive and press any keys when ready and when we press a button it does it again and again
  • 55 Answers
Go to bios settings and change the primary boot device from cd-rom to hdd
Posted on Nov 22, 2008
  • 903 Answers
Make sure that there is no cd or floppy disk in the drive and try again
Posted on Nov 21, 2008
Reset factory settings for toshiba S241-504
Back up all of you data to an external drive before you begin the process
If you make a mistake during the process, your laptop may not be able to turn on or load the
operating system, so copy valuable information to media where you can retrieve it, even if your laptop malfunctions.
Turn on your system and wait for it to finish loading Windows and start-up programs.
You can tell when the operating system has loaded, and start-up programs have been initiated, by the HDD (hard disk drive) light.
It should have came with discs. Put one in and reboot the laptop
Insert the system disk when the hard disk light stops blinking, signaling that the processor has finished accessing the hard disk, and that the system is idle. Shut down your laptop after you insert the disc.
You do not have to wait for the computer to access data from the disc.
Turn on the laptop again. Keep pressing the "C" key continuously as the system boots. This will enable the laptop to boot from the disk. Once the disk is accessed, the laptop will show
the message "Loading Files;" begin the factory reset process by always selecting the default option that pops up.
You can also use the "F12" key to boot from the disk.
Highlight the CD/DVD option and press "Enter" to begin the restore process.
Follow the on-screen instructions until the process finishes
Restoring a Toshiba laptop back to factory settings may take 30 to 45 minutes.
Unless you terminate a process by pressing "Cancel," your laptop will be rolled back to factory defaults, when the operating system installs completely.
hope this helps
Jul 18, 2012 | Toshiba Satellite Computers & Internet
How to fix error loading operating system on toshiba satelite m115 laptop
Go into the BIOS and check if the BIOS detects the hard disk. If not then most likely the hard disk has failed and the hard disk needs to be replaced then Windows needs to be installed on the new hard drive plus the Toshiba M115 device drivers and your programs/software.
Feb 02, 2012 | Toshiba Satellite M115-S1061 Notebook
Dvd backup of os
You will need to run the Recovery Media Creator application provided by Toshiba with your laptop if you do not have a backup / recovery disk. The instructions for doing this are documented in the User Guide for the Toshiba Satelite L755D on the Toshiba Support web site. . . . .The User Guide is a PDF document contained in a ZIP archive.
Dec 22, 2011 | Toshiba Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I am having problems with my toshiba satelite laptop mod# A55-s306. following error message appears when it is turned on: PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE-M0F: EXITING INTEL BOOT...
What you should do is in the following order:
1.Go into bios and load defaults (usually hit F1)
2.Go into bios and set the boot sequence as HDD number 1
3.Go into bios and disable network PXE boot if possible.
4.Now retry
5.No success press F12 and choose HDD as boot up
6.Now retry
7.No success then remove the HDD clean the contacts and reseat
8.Now retry
9.No success open the laptop lid locate which part of the laptop the hdd is located and just give the laptop a tap in that corner and abit of a push (with the laptop turned OFF) Ive successfully fixed 2 of my IBM's doing this.
10.Still no success try changing the HDD and reformating a fresh
11.Still no success i would open the laptop up completely remove the motherboard and oven bake your motherboard and 375f for 10 minutes BUT BE WARNED DO A GOOGLE SEARCH BEFORE DOING THIS!. This method can also repair other faults such as GPU faults, Memory faults..ect.
May 07, 2011 | Toshiba Satellite A55-S306 Notebook
Hi,toshiba satelite pro L20 beeps when start up
Run check disk for hard drive errors. I recommend immediately backing up all your data that you can, wiping it, and reinstalling your programs. The rebooting problem smells like a bad hard drive. I just went through it with a Compaq at work.
Sep 16, 2009 | Toshiba Satellite Pro 6000 Notebook
Problem with toshiba laptop 1996 need help
Jan 23, 2009 | Toshiba Computers & Internet
Need to know If I can use this hard drive in this laptop?
More than likley its not inserted all the way. See if it shows on the boot menu in BIOS. To get to BIOS in TOSHIBA units I believe its F2 at startup.
Nov 30, 2008 | Computers & Internet
Toshiba Disc Drive Not Working
Please can you tell me what operating system you are using ie XP?
If you go to my computer can you see the disk drive listed ie pic of mine, notice I also have a external drive attached (x)
Jan 29, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
