Question about Samsung Cameras
3 beeps on samsung digimax cyber 530 - Samsung Cameras
  • 3,230 Answers
Well it's just because of lens errors, they are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism.
Follow the below steps to do a try to correct it -
1. Remove the batteries from the camera, wait a few minutes. Put a fresh (or new) set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on. 2. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). 3. Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots. If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Samsung Service Center. Aprox repair cost is $120.
Thanks for using FixYa!!
Posted on Jul 07, 2010
Samsung Digimax Cyber 530 does not show image on screen
Check the memory cards on your PC for the quality of the images that were shot now. if there is no fault seen the fault is in the display section. It can be a fault of the LCD or the failure of the flexible strip to the LCD.
May 06, 2011 | Samsung Digimax S500 Digital Camera
Operating manual for samsung digimax 530/5100
You can get the manual on the link below.
http://upload.cyfrowe.pl/cyfrowe/instrukcje/aparaty/samsung/instrukcja_samsung_530_eng.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Oct 28, 2010 | Samsung Digimax 530 Digital Camera
Lost my manual and guide to my samsung digimax 53 camera 5.0 mega pixels can you help me out please?
Do you mean Digimax 530 ?
Go to http://www.retrevo.com/support/Samsung-530-Digital-Cameras-manual/id/563ci662/t/2/
Jun 01, 2010 | Samsung Cameras
Will a 4gb hp sdhc work with a samsung digimax cyber 530 camera?
Your model is identical to the Digimax S500, the name is different only because some Samsung model numbers change according to who sells them.
Your camera is compatible ONLY with SD cards, it does not support the later SDHC standard. There is no possibility of updating to the later standard as it's a hardware limitation.
This theoretically means that you're limited to 2GB maximum, but even that's risky as Samsung specifically state on page 64 of the user manual that compatibility is only guaranteed up to 1GB.
I hope this has helped you to purchase the correct memory card, all I ask in return is that you kindly take a moment to rate my answer.
Feb 13, 2010 | Cameras
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Camera will not take a picture
an idea passed over my head just now
several ideas
was the camera droped
was the camera exposed to heat
was the camera exposed to static electricity
was the camera exposed to water or liquids
ect.
if these or other things happened to camera
the shutter inside camera has malfunctioned due to the reasons
May 10, 2008 | Samsung Digimax S500 Digital Camera
Lens stays neither closed nor opened when power off
try to slightly push it in slowly while it is going in manully
Apr 03, 2008 | Samsung Digimax D53 Digital Camera
Samsung Camera mod DIGIMAX S500/Cyber 530
still that happens to me sometimes...this is when you need t o charge your battery over again fully....
Dec 28, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
257 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
