Cozy Wall Heaters
Thanks for reading this query.  I have a Cozy W255E-R mounted wall heater.  I was adjusting the theromostat on the wall when the pilot light blew out.  Attempts to relight were unsuccessful.   I dont know where the match is supposed to go or exactly in which position the black dial is supposed to be to be in lighting position.  Unfortunately, I also cant come up with the instruction manuel.  If you have any suggestions or a link to the instruction book on line, it would be greatly appreciated.
sincerely,
Bryan
  • Anonymous Dec 02, 2008
    waht type of thermocoupler and how to installed
  • 1,420 Answers
On the gas valve, look for a marking that indicates "Pilot". If there is no such marking, you do not have a pilot and the system is electronic ignition. Ok so if you find the pilot position, you will be able to turn a know to that position and depress the knob into the gas valve. At the same time you are depressing the knob, look for a red button that snaps when you depress it. This is a Pizo starter. If you do not have this button, look for a viewing port where you can insert a long match. Once you have the knob depressed and the viewing port open if needed) you should be able to light the pilot with the snapper or match. Before you release the knob on the gas valve, sing "Yankee Doodle". This will give the flame enough time to heat up a probe to the proper temperature and the flame should stay on. Button up any port you opened and then turn the gas valve knob to the "On" position.
Posted on Nov 21, 2008
How to adjust the burner flame , it is blue and it is going down , its a cozy single wall furnace
gas pressure should be 3.5 on natural gas and 10 on propane, also make sure burner is clean.
Feb 26, 2015 | Cozy Heating & Cooling
I have a cozy gas heater model # vcr701a-r can i change the thermostat to digital?
i read its a on off switch connected to it
thats what all wall mounted temp controller do they close a circuit thats phantom power supplied in your closet
buy any thermostat you want an it should work with this unit easily. all are battery power now days.
Jan 05, 2015 | Cozy Heating & Cooling
Cozy wall heater
Check flue pipe,old flue pipe may have soot,also check vent flashing may be restricted
Jun 25, 2014 | Cozy (W352E) Heater
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
Cozy wall heater,incomplete combustion,is the flame [gas] adjustable?
try cleaning the burner and the orffice first and the air ports to the burner
Aug 17, 2010 | Cozy (W352E) Heater
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
Wires not connected to gas valve need wiring diagram for Cozy wall vent heater
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
Dec 10, 2009 | Cozy (W352E) Heater
Cozy hi-efficent wall furnace HEDV403
what you are doing is reseting the heater when you unplug it there should be a overheatswitch that is cutting in and shutting it down
Jan 11, 2009 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
318 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
