Question about Mintek DVD-1810 Portable DVD Player \
Disc will not load!
I insert a disc into my Mintek 1810 Portable DVD Player and the screen tells me it is loading. After a few seconds, the screen says "NO DISC"
Please tell me how to get this player to work properly as it did in the past.
Thank you for your attention to this critical problem.
Howard
  • 59 Answers
The dvd player has problem with the lens get lens cleaner to clean the lens that will solve the problem, after you clean the dvd player lens with lens cleaner play the disc again if it tell you know disc again play another disc with the player, if the same that means the dvdplayer lens has damage you can then change the dvd lens with good lens. but if is minor dust the lens clean can be able to solve the problem.
Posted on Nov 21, 2008
    Top Expert:
  • Mintek Master
  • 78,267 Answers
This may be a hard part failure, but 1st go to the Device manager and remove the disk player from the list of devices loaded in your system, then turn off the PC and restart, it should say found new hardware and reload the player
  • yadayada
    yadayada Nov 21, 2008
    I have had this problem on my own PC and used what I suggested to clear it, but if it doesn't the DVD device is defective, they are real cheap, just replace.
  • 2,335 Answers
The part that reads the info from the disc might be defective or need to be clean using a lens cleaner. Another problem could that the lens mechanism did not come back to the home position and a switch is not activated to let the microprocessor knows to read the disc.
Let me know if you need further assistance.
  • Mintek Master
  • 19,396 Answers
That means that the lens are dirty or defective.
Try using a DVD lens cleaner disk, often when you get no disk it is because of a dirty lens.
Here is a choice of lens celaners, get a good one with liquid solution and try.
If that does not work, then you will need to have a technician taking apart the DVD and cleaning the lens manually, or replacing the defective lens pickup.
    Genius:
  • 3,422 Answers
HI,
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
Also Make sure your box is not blowing really hot air and nothing is right behind it blocking it.. Turn it off for a few minutes and let it cool down and then give it a try playing the discs..
    Sergeant:
  • 276 Answers
It the lens error which cannot read the disc which u insert.eitheer the lens is dirty or needs replacement.
  • 2 more comments
  • smarttech Nov 21, 2008
    still u can check out that same disc in any other player and check out.if the disc is really faulty itself then also it will show no disc.
    The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
    1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-25 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
    2. The cd tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull and push on the cd tray.
    3. The small gears are plastic and often break, this will cause the players other parts not to move and function properly also. They are hard to get to, but inexpensive to replace from the manufacturer. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
    4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are a pain to put back on also. There are usually 2-3 of them inside your player.
    5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might as well buy another player unless you can find a great deal on one someplace. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc.
    6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on. Check these two components if you are having problems with your cd tray.
    How to Fix a No-Disc Error on a DVD Player
    Step1Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
    Step2Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
    Step3Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
    Step4Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
    tep5Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
    Step6Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
    Step7Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money
    Things You’ll Need:
Problem with Mintek MDP-1810 Portable DVD Player that will play movie DVDs but not computer burned video DVD
The problem I think is with the burner on your pc. Try re burning on another program like Nero and pay attention to the options. It will ask you if you wish to play disc in all types of players.
Dec 25, 2013 | Mintek MDP-1810 Portable DVD Player
My screen is cracked where can i get it fixed
see the cause and fix it:
1er alternative:
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
  3. Try a direct connection from the DVD player to the TV set, instead of via other components.
  4. 2nd alternative:
  5. Enter Setup and then Player menu to select the correct screen format.
  6. Select the screen format from the DVD disc menu or press zoom key.
Jul 21, 2012 | Mintek MDP-1810 Portable DVD Player
It continues to say no disc even when a disc is loaded
The problem is in the laser pickup assembly, overtime the laser becomes weaker until it can no longer track the dvd disc, It is far cheaper to replace the dvd player than have it repaired.
May 21, 2011 | Mintek DVD-1810 Portable DVD Player \
I load disc, it spins but no pic/sound
you better take it to someone professional in the domain as your portable dvd player seem to have problem with its laser
Oct 04, 2009 | Car Audio & Video
No disc error
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 22, 2009 | Mintek MDP-1810 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Charger for Mintek portable dvd player 1810
eBay has a few charges for your portable dvd player.
Mar 19, 2008 | Mintek DVD-1810 Portable DVD Player \
Mintek DVD-1810 Portable DVD Player \ Logo
43 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
