This evening the camera was working fine for about 6 pictures. After that (did I hit something on the camera?) all my pictures, with or without flash, are seriously whited out. I do not have the nightframing or other night option turned on. I've tried manual mode and same result. Also-- I can't find the manual to the camera. Thanks in advance, Coonrad
-   same- but mine is an optical zoom 3x-   Guest
Dec 01, 2008
-   i have a t3 5.1mp and suffering form the same problem. except when i used Frame burst...or other mode...it takes the picture perfect on the second shot. any sugguestion?
-   twodimension
Dec 01, 2008
-   i have the same problem only its a t3 sony 5.1 mp. what is the problem here?
-   Guest
A bright LCD usually means no signal to the LCD - a loose connector. A temporary fix is to tap it - if you're lucky the connector will reconnect. The long term fix is to disassemble and reattach it. It's a $50 job by an independent shop. Let me know if I can help contactus@crystalcamera.com
Im still trying to figure this site out, but do you have an F717? If so then its your CCD, not your LCD. If your photos are white it has NOTHING to do with the LCD screen, dont know why somebody would suggest that. If you have an F717, its covered under a CCD recall from Sony they will fix it free.
Sony Cyber-shot DSC-F717 Digital Camera. The screen is smudged horizontally and there is a green...
(More)
Sony Cyber-shot DSC-F717 Digital Camera. The screen is smudged horizontally and there is a green tinge, it is only on the viewfinder and LCD screen. When i upload the images to the computer they are perfectly fine. Is it possible to fix this problem?
Sony DSC-F717 will not operate in battery mode (replaced the battery). Works ok when power cord is...
(More)
Sony DSC-F717 will not operate in battery mode (replaced the battery). Works ok when power cord is attached.
my camera isn't taking any pictures even though it's on, and the lens is off. I'm pointing at...
(More)
my camera isn't taking any pictures even though it's on, and the lens is off. I'm pointing at objects, but the screen appears black, please help!
I would like to restore all the setting to original factory setting when I bought it. I followed the...
(More)
I would like to restore all the setting to original factory setting when I bought it. I followed the recommendation, removing battery while press power button, it didn't work. I'd like to set manuel. Do you have that info? thanks
external flash will not override internal flash - the subject ends up with very harsh over-lighting....
(More)
external flash will not override internal flash - the subject ends up with very harsh over-lighting. in other words, both flashes go off when i have the camera flash set "on". this is with the hot shoe function "off". if i turn the hot shoe function "on", then neither flash works (internal or external).
