Specifically, how would someone go about doing a convergence setup on a RCA P56940 56" projection tv? There is problems with both vertical and horizontal alignment. The three colors and separated and the picture has a concave arch to it both top and bottom.
-   Specifically, how would someone go about doing a convergence setup on a Panasonic 56" projection tv? There is problems with both vertical alignment. There is a blue color separated and the picture has a concave arch to the top.-   avitosh
Feb 24, 2008
-   The colors are misaligned and the picture has a convex shape,-   Guest
Nov 06, 2007
-   My picture appears to be concave.-   Guest
It can be done without Chipper check. Go to Parameter 80 and it can be done .First correct any green geometery. Then work from there. All this is covered on the ptk 195 cd
Convergence on RCA P56940 chassis PTK195 can only be done by service center with RCA Chipper Check computer interface box. Sounds like possibly missing -15 volt or +15 volt supply to digital convergence circuit, bad i.c.'s U19503 or U19504. Supply voltages come from regulator supply transformer T19701 diodes CR19707 (-15 volts) and CR19709 (+15 volt)
I have a panasonic 52 inch projection comes on get red lines and then shuts off and light flashes 4...
(More)
I have a panasonic 52 inch projection comes on get red lines and then shuts off and light flashes 4 times
How do I remove the top part of a PT-53WX53 panasonic rear projection tv. I can get the back off...
(More)
How do I remove the top part of a PT-53WX53 panasonic rear projection tv. I can get the back off but not the top part off. My Mini-van isn't big enough, so i need to split it into two parts to transport it.
My panasonic 1080i is really dark. It is hard to even see scences that are meant to be dark. I do...
(More)
My panasonic 1080i is really dark. It is hard to even see scences that are meant to be dark. I do not have original remote. How can I fix it?
