Question about Magellan RoadMate 700 GPS Receiver
No map data no hard disk
Magellan roadmate 700 was working. now it boots up fine, but displays can not read hard disk I can continue with no map data, but it simply points north and the satellite spins. ouch thomas
    Novelist:
    Scholar:
  • 86 Answers
Typically I'd change out the hard drive. Your not able to access your location on the map right? or are you able to access the map at all? In your position, if your product is OUT of warranty. Open your unit up and make sure the cable going from the main board (big one) to your hard drive are tight. Other then that, try resetting user data. At the user menu (after restarting) press "-" and repeat button at the same time. Scroll down to reset user data, then see if anything changes. I'm almost positive it's your hard drive, and you can't just go out and buy one of those. So, good luck.. if nothing else you can just send it down here to Fort Worth, Tx.
Posted on Jan 05, 2007
No map available
It is quite likely that any maps you obtain from others will not work in your GPS as maps are coded back to component parts in the unit ANTI PIRACY codes .Similar to MS serial numbers. It reads ID's and checks against those stored in map. The only option is to purchase new maps for the area you want.
Jul 24, 2009 | Magellan RoadMate 800 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
As posted in another place, it took two tries for me to install the maps. Hopefully, you already were successful and haven't visited back to update your question.
Feb 07, 2008 | Magellan RoadMate 700 GPS Receiver
Roadmate 700 error message "No map data on hard drive"
Did the update fail? Sounds like it. You might want to try the update again.
Feb 06, 2008 | Magellan RoadMate 700 GPS Receiver
Map Data Locked
do not bother i had a 700 roadmate they start having lots of problems like fozen screens to losing satilite signals ,get the magellan mastreo 4000 or the roadmate 800 both are portable and has rechargable internal battery,800 you can buy extra batterys,the 4000 has no extra batterys to buy,they both have windows core 5.0 and i have both of them the are real good with no problems.belive me .
Nov 17, 2007 | Magellan RoadMate 700 GPS Receiver
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
How to hard reset magellan 700
Hussam.. I believe the newest software upgrade you can get for the 700 is version 4.32 which is the same version used on the 760's. The maps are stored on the hard drive, so I do not think a reset will help but here is how it's done. 1. At the user select menu (first screen to appear after initial turn on) hold down the zoom out key (-) and the repeat button (on top of your unit). 2. Once at the "secret" menu, select reset user data. This will reset all of your personal information from the unit. All of your POI's will be deleted as well as your user name (which you can re-create of course) 3. Your unit will re-boot automatically and that's how you reset your unit. Like I said though, I do not think this will revive your maps. If you have the maps on a DVD-CD then you can reload them that way, otherwise send it to the Fort Worth, Tx repair center and they have the proper program to load data directly to the hard drive. Good luck! -Daniel
Jun 28, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 can't power up 2nd time in car
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Jun 19, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS unlockmap
Steve, In this case I would replace the Hard drive. But, since you probably don't have spare HDD's lying around.. do you atleast have the Software version? Some CD that came with it hopefully. If you do, then you may be able to stay alive here. Once your system boots to the user screen.. press + and repeat key at the same time.. "secret" menu now. ONLY IF YOU HAVE SOFTWARE TO INSTALL!! Select NAND FLASH FORMAT.. The unit will shut down after formatting. start up your software installer on computer. plug usb in.. and power on unit. This fix isn't %100, but it's the best shot you have. Otherwise you've gotta send it down here to Texas (where magellan repair is) and pay for the new hard drive. OR.. you could call customer service and see what they have to say. you'll probably be transferred to overseas.. --good luck with that -Dan
Feb 07, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
115 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
