Question about Sansui TVS2750 27"
Sansui sv2918 no picture blue screen white lines sound ok
When the tv is switched on, a black and whit pic appears for 10sec the the screen turns blue and white horizontal lines appear.
Note - sound is ok
bkvinr
  • 76 Answers
SOURCE: Horizontal White Line
In your statement i found during switch on you get picture. Check whether in a few minute picture suddenly goes to the horizontal line or height reduces and then goes to line. If suddenly goes means change any zener diode in pumpup circuit. If it is not means LA 7840 ic getting imbalanced supply voltage i.e.,negative and positive voltage are not equal. Suppose only one vcc means supply resister getting high ohms and change the the supply resister.
Posted on Aug 24, 2007
  • 1694 Answers
SOURCE: Sansui SV2918 has no picture and audio only a blue screen
Have you tried the a / v inputs?? If they work,might be a bad tuner.If they don't work,then your symptom is no video-no audio=
power supply problem? Check all voltages....T.
Posted on Oct 25, 2007
SOURCE: sansui tv sv2918
Sweetch on thr tv just one vertical line comming in center of ty screen
Posted on Jun 20, 2008
replace vert IC301, C432, ( D431 & R431 should also be blown)
Posted on Nov 26, 2008
  • 979 Answers
SOURCE: Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
Posted on Jul 10, 2009
Sansui sv 3220 lcd screen just white,but sound ok
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 23, 2015 | Sansui Televison & Video
No picture, no menu, black screen, no raster, sound ok
From your detailed description, it sounds that the main chroma processor IC has damaged. Raster means nothing, but the lighted screen that appears, when a TV is switched ON. For some brands, there will be a blue screen; when there is no signal input, and some others will have a bright white screen with some snow.
I advice you to contact any service technician, to get this TV repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Televison & Video
I want to connect sansui dvd to Samsung led television
There are typically 3 ways depending on the age of the dvd player.
Red White and Yello RCA Jacks (Out) of DVD to (IN) on tv Red, Green, Blue rca Jacks and red and whit rca jacks(Sound) Or, an HDMI cable which transfers both sound and picture.
Jun 17, 2014 | Televison & Video
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Philips 27PT6441 27" TV Problem
jon5902,
Pls note that my experience is with the phillips 27" model27PT6341/07. It may not be the same board as yr model, as I can't remember nor find the service manual anymore. (browse around online for it though)
However, after taking the back off. Look close to the rca jack and svideo connection. Mine is located about an inch from the svideo connection.
Here are some pics that may help you.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
The new one is the black and gold one marked 10uf 100v in the pic.
Other users have advised to go as high as 10uf 250v, to avoid having the cap overload again.
PS. I had the lines for about 2 weeks. They got steadily worse then one day my tv looked like it was broadcasting an hourglass. The lines converged in the center and flared outward (no pic).
Sep 10, 2008 | Philips 27PT6441 27" TV
Sansui tv sv2918
Jun 18, 2008 | SansuiM1315 TV
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
Dec 03, 2007 | SansuiM1315 TV
Sansui TVS2750 27" Logo
101 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
