Question about Linksys Wireless-G WRT54G Router
No connection When trying to install new router I am getting a message"not able to connect to internet..." and the internet light on the router is blinking (all the other lights are steady) After I recconect my cable router to "main" computer everything is fine. I have tried different cables, all seem to be OK. but as soon as I connect cable modem to my wireless router I am loosing internet connection on the "main" PC. Where is the problem
  • 8 more comments
  • Anonymous Nov 05, 2007
    wireless router is not working
  • boatal Jan 01, 2008
    My verizon modem works fine. I setting up my wrt54g as instructed. I lose the verizon connection, but have a local area connection, but can not get on line. I’ve been trying for days to correct this problem but nothing has worked.
  • Anonymous Jan 03, 2008
    I have the same problem all the light are there, but I cant get internet .I have done a command prompt got responce but stii cant get internet wireless says connected
  • Anonymous Jan 05, 2008
    unsecured network
  • sanjaysonia Jan 05, 2008
    i need help to install my router .
  • nefty Jan 07, 2008
    I have a new Dell Desktop Computer, with Vista andI am having problems connecting to the internet. Trying to download the linksys software and it says not connected to network. need help
  • tishb Feb 15, 2008
    When I'm setting up the router and it tries to connect to the internet it says no connection can be found but the the light is on on the router and when I connect my computer without the router I can get to the internet without a problem.
  • Anonymous Feb 18, 2008
    can't connect to internet through my router
  • ladylady Apr 17, 2008
    I installed the router it seems like it is succesffully installed, I had to connect the New Network Cable to the computer and I connected the New Network Cable that is connected from the Router to the cable modem, once that was done I referred back to the directions and the directions say that Once everything was successfully installed, I can un-hook the New Network cable that was connected from the cable modem to the computer, Once I took my Labtop upstairs I wasnt able to connect to the internet.
  • backup444 Jun 08, 2008
    I can not get on the enternet with the wireliss router
  • Linksys Master
  • 2,270 Answers
First make sure that your computer is able to go online when connected directly to the modem. if that is working then connect the modem and the computer to the router. Reset the router for 30 seconds. You will find the reset button on the back side of the router. Hold it down for 30 seconds. Unplug the power to the router. Plug it back in. wait for a minute. Now open the rotuer set up and configure the router.
Click Here for step by step solution
Posted on Nov 28, 2009
  • 83 Answers
Whenever you plug a different device into a cable modem, i.e., switch pc's or switch pc for router.  You MUST repower your cable modem.  The cable modem remembers the last hardware address that was plugged into it and it will not recognize another hardware address until the cable modem is rebooted.  Then power up your router, wait for it to get it's address from the modem and then power up your pc.
Posted on Apr 24, 2009
  • 106 Answers
You sound like you're using Cable simply because you're able to unplug and replug the computer.
Unplug your cable modem for 30 seconds and plug back into the router and you're on your way!
Posted on Jun 15, 2008
First off, are you connected by dsl or cable or sattelite? If the answer is dsl we have to first put the modem into full bridge mode. The modem is probably got DHCP enabled and MAC filtering enabled. You can call your ISP for that answer but if that isn't reasonable then you can find the ip that the modem is giving you by: First make sure the modem is plugged directly into the pc and you have internet connection; Now click on "start" and choose "run" . When the dos shell prompt opens type "ipconfig" and press enter. The "default gateway" will probably be 192.168.1.254 or something close to that. Make note of the default gateway and open a web browser. Now type the default gateway number you got into the address field. It will ask you for a user name and password. most use "admin" for the user name and "password" for the password, If not you will have to call the ISP (Inernet service provider for these. Once inside the modems main page click on the "LAN settings" and uncheck or disable the DHCP. Also, turn off MAC filtering. Now press save. Wait for the modem to reboot and continue on. If you have cable you don't have to do this. Once that is done make sure to reset the router back to factory defaults, by pressing the reset button in the back of the router and holding it in for a full 30 secs ( Usualy it is a small hole that maybe a paper clip or the head of a pin can fit in.) Next power cycle the system. Turn off the modem router and pc and wait 30 secs. Now bring up the modem first and allow all the lights to stablize. Next bring up the router and let all the lights stablize. Finally, bring up the pc. Now run the wizard and thats all there is to it.
Posted on Mar 11, 2008
    Problem Solver:
  • 8 Answers
First try to confirm if you have internet connection directly thru your modem. if you dont have any connection the problem is with your modem. return it back to the isp then let them replace it. but if theres a connection try these solution that im suggesting.
try to do a power cycle..unplug the cable of your modem to the router then unplug the cable of your pc to the router.let it stand for 30 seconds then plug back the modem to the router's internet port then plug back the pc to the numbered ports... go to the run tab then type in cmd then you will see a black box type in ipconfig..if ull see a ip address pls try to ping it
ping 192.168.1.X if you will receive 4 replies your connected but if you ull received a ip add 169 try to reset your router. at the back panel of you router there is a reset button. get a pin or something then push the button for the reset. count at least 30seconds for restting. power up your computer then go to the command prompt. type in ipconfig then if your receive a valid ip address thats the time to check your other computers if its working properly then try to connect to the internet.
if still u cant connect the problem is with your isp or the problem is with your modem
Posted on Jan 17, 2008
I had this same problem.
The Routers address : 192.168.1.1 was conflicting with my modems address : 192.168.1.254 why , i have no clue. Yet , i changed the routers address to 10.10.10.1 and everything came out ok and i can now connect to the internet. Also ... when it wouldnt work with my modem in the routers "Internet port" i just plugged the modem into one of the othet ports and evreything worked good. BUT.. then the routers acts as a HUB not a router..
Posted on Dec 24, 2007
    President:
  • 2,961 Answers
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter. Although my advice would be to return your router back to the shop and claim that you are no expert and that you have been advised that a Wireless Modem/Router is more suitable than a seperate modem and seperate router.
Posted on Dec 22, 2006
  • 589 Answers
You didn't specify if you're using DSL or cable.
I've run into this dozens of times. With DSL, keep in mind the software on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Posted on Jan 07, 2008
New router as of today Belkin F5d8236-4, wont connect
You will need to configure the router manually
Tell me the name of your internet service Provider ??
Dec 31, 2009 | Belkin F5D8236-4 Router
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Just installed new router but cannot access
Run the setup wizard on the router and have it detect the "WAN"
Choose the defaults, and you should be good to go
Nov 04, 2009 | Heating & Cooling
Can't connect 2wire to internet
Before router put usual low cost switch....
May 21, 2008 | Computers & Internet
Ive installed xp on my acer travelmate 4100 laptop
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
Apr 22, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
4200 speedstream modem problem
I guess you probably aint set-up a wireless router before, what you need to do is get it connected up so you revieve local area is connected then, load internet explorer you will recieve a message like page not displayed. where you usually type in www.ebay.com for example type in the number thats on the bottom of the router ie it looks somthing like this 192.168.1.1 for example. a menu will then appear, fill in your broadband username details etc and you should be up and going, if you have problems feel free to email me,, All the best John Auctionscotland@tiscali.co.uk
Jan 17, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
I cannot get connected to the internet.
If I understand you correctly you currently have a computer connected directly to your ADSL Internet connection and it can connect to the Internet. When you disconnect the computer, connect the DG834G router to the Internet connection and then connect the computer to the router you loose the Internet connection. It sounds like a ?simple? case of the router not being configured correctly. What I would suggest is to reset the router to its default configuration and follow the installation instructions again from the start. I?m not a big fan of the software configuration wizards that these home routers come with BUT they are the best way to easily configure the typical installation. To reset the router: in-between the 4 Ethernet LAN ports and the ADSL port there is a small reset button. Press and hold the reset button until the test LED turn on (about 10 seconds). Release the button and wait for the router to reboot. Let us know if this works or not. If you still have problems the more details and error messages you can supply the better.
Dec 29, 2006 | NetGear DG834G Router
Linksys Wireless-G WRT54G Router Logo
595 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
