Question about Whirlpool GR465LXLS Electric Kitchen Range
Sf114pxsw1 lp conversion
Burner flames are very high and oven has lp smell i don't thank this was converted i don't have a install book
    Habit-Forming:
  • 171 Answers
On the regulator of the stove there is a knot tha you swich to propane it have the latters lp or nat.swich it to Lp. you most open the air vents on all the burners.
Posted on Dec 06, 2008
Converted HotPoint RGA720 to LP, burners and oven work fine, all pilots flames are still too high?
I have this model too and have had to replace two thermocouples because the pilot is so high it frys them. We replaced the whole modulator last time and it still goes out so I have to relight The pilot is at the lowest setting, it's a GE/Hotpoint issue that was not recalled. I do like the hot 125 degree oven for drying sun dried tomatoes and keeping plates warm.
Apr 13, 2013 | General Electric Hotpoint® RGA720PKWH Gas...
Convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Jul 20, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
Rangemaster 110 LPG Range (5364) right hand oven lights but flame only stays low? What is the likely problem please
Is this new and recently converted to LP-Gas? Did you install it and convert it or did you have a professional do it? It sounds to me like the wrong size orifice for the oven may have been put in. Was the appliance regulator converted? When you flip the cap, it allows more pressure to the burners, but this affects all stovetop & oven burners, not just one burner. Some ovens require converting the oven thermostat too, but not sure if it applies to this brand. Check your owner's manual and make sure all the steps in the conversion were done. If you had a pro install and convert it, call them back to fix it. Douglas
Jun 12, 2010 | Rangemaster 110 (Gas) Kitchen Range
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
May 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Oven flame is too high
the flame should be app 2" from each side of the burner. be very careful with lp conversions.
Feb 09, 2008 | Frigidaire GLGF382D Gas Kitchen Range
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool GR465LXLS Electric Kitchen Range Logo
199 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
