Question about HP Compaq ProLiant DL580 G4 (430811001) Server
Fan flow error 1611 I/O
After power down we receive 1611 I/O Fan error. Server is old and we could not find documentation. Please help!
    Guru:
  • HP Master
  • 829 Answers
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Posted on Dec 17, 2008
2 Suggested Answers
  • 2692 Answers
SOURCE: Fan flow error 1611 I/O
Either the Case fan or the CPU fan has failed.  Replace it .
Your HP support site for you product below: G2, 3, 4, 5?
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=+Compaq+ProLiant+ML370&submit.x=4&sub
Posted on Jan 18, 2009
Ricoh c6501 sp error coad sc 925 solution
SC925 B Net File function error *GW The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code: • Refer to the four procedures below (Recovery from SC 925). Here is a list of HDD status codes:
Display Meaning (-1) HDD not connected (-2) HDD not ready (-3) No label (-4) Partition type incorrect (-5) Error returned during label read or check (-6) Error returned during label read or check (-7) "filesystem" repair failed (-8) "filesystem" mount failed (-9) Drive does not answer command (-10) Internal kernel error (-11) Size of drive is too small (-12) Specified partition does not exist (-13) Device file does not exist
Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
  1. If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on.
  2. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-11 (HDD Formatting - Ridoc I/F).
    NetFiles: These are jobs printed from the document server using a PC and DeskTopBinder. Before you initialize the NetFile partition on the HDD, tell the customer:
    • Received faxes on the delivery server will be erased
    • All captured documents will be erased
    • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
    • Documents on the document server, and scanned documents, will not be erased.
    • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
  3. Before you initialize the Netfile partition with SP5832-11, do these steps:
  4. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  5. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
  6. Do SP5832-11, then turn the machine power off and on.
Procedure 3
  1. If "Procedure 2" is not the solution for the problem, do SP5832-1 (HDD Formatting - All)
  2. Cycle the machine off/on.
Apr 12, 2016 | Ricoh Office Equipment & Supplies
Konica minolta di 1611, di 2011 driver windows 7 32 bit. konica minolta di 1611, di 2011 driver windows 7 64 bit pozdrawiam Jarek
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
Feb 10, 2011 | Konica Minolta Di2011
Compaq dl380 g1 - 1611 Power Supply 1 Fan Failure Detected
it only ur fan problem which one of the four fan or two ,might be stuck or jammed which starts after of couple of restarts, so i sugest u to check the fans when in operation
good day
Jun 01, 2010 | HP Compaq Proliant DL380 G1 Server
How i turn off a fan from motherboard
The fans that are plugged into the motherboard are usually powered by the motherboard. To turn them off, simply unplug them as there is always a power flow going through the motherboard and even more to power the fans when the system is running. I would recommend keeping the fan in if possible to help with cooling your PowerEdge 1400 server, but if it must be removed, simply power your server down, and unplug the fan. Make sure your server is powered off before doing this, as you don't want to short anything out or cause a spark.
Mar 13, 2009 | Dell PowerEdge 1400...
HP proliant dl 360 g3 error code 1611 cpu fan failure
Remove all 6 fans, and then remove the fan rack itself. Then tighten the 2 pcb thumb-screws underneath. I believe this is sometimes the reason for false 'failed fan' reports.
Feb 02, 2009 | HP Compaq ProLiant DL360 G3 Server
I have a HP Proliant DL360 G3 which I host a small radio station from. It went down the other night and when I went back to check on it, it was still running but I couldn't get the monitor to come on. So I...
Did you check the connection on the CPU zone up near the front interior of the server? They are like two black modules that sometimes get loose. If you open up the case, near the front left (usually) there you can push the modules down and make sure they are set properly, then try to power up server again. Let me know if that doesn't work and we can try something else.
Feb 02, 2009 | Computers & Internet
Jan 16, 2009 | HP Compaq ProLiant ML370 (102118-031)...
In what folder are received faxes stored to on XP
the address of fax folder is given to the server. thats why it is giving such error. normally files received in my documents "my received files" folder.
Nov 29, 2008 | HP LaserJet 3300mfp All-In-One Printer
Error... the Fiery Server Interface timed out, please, check the Fiery
Sir, I have Document Centre ColorSeries 50 In this machine Scanner is not working, in the Machine Display showing : Error... the Fiery Server Interface timed out, please, check the Fiery. Please help me
Sep 24, 2008 | Xerox DocuColor 12 Color Copier
HP Compaq ProLiant DL580 G4 (430811001) Server Logo
6,769 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
