Question about Canon imageRUNNER 210S Copier
Canon 330 image runner Error code E000
I just bough this machine and brough it and turned on. I am getting e000 when ever I turn the machine on...why? what's wrong with the machine.
  • Anonymous May 03, 2009
    quando ligo a maquina ela ja reinicia com um erro , e com esse codigo.
    e000, pode ajudar ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
E000 is a fuser problem.
take out the fuser (this is where the paper exits and gets hot) the tow long big rollers, the lamp may have blown or the thermofuse (keeps the copier from over heating and going to meltdown) may be bad.
The newer ones (not sure about this model ) have a ceramic instead of a heat lamp and also a thin brown film instead of rollers.
if it has a film make sure it is not torn or displaced.
Posted on Nov 21, 2008
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
Error000
This error means that the Fixing heater is not working. It has not reached operating temperature after a specified time. It has probably blown the heater element.
You will need a trained technician to repair this.
E000 errors will not clear until the fault has been rectified and then reset by a technician. This is to prevent any fire risk.
Apr 30, 2010 | Canon Image Runner 1630 Copier Copier
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
E000
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003. Here's the definitive reset procedure Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
Jul 06, 2009 | Canon Image Runner 1630 Copier Copier
The Screen on Canon Image Runner says E000 - can't make copies
Your Fuser just went , Call you Canon independent or Authrized dealer, he will need to go into the simulation to reset this error. Usually E000 is either a fuser or fuser web error. I'll need to look this up in the service manual. most likely you'll need a quailify technician to reset this error code.
Mar 04, 2009 | Office Equipment & Supplies
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Image Runner 210S
it is a fuser problem:-you have to check-.
1-low temprature due to blown lamp(change it).
2-thermal switch(reset it)by pressing on it.
3-ac driver problem(heater control board.
Apr 20, 2008 | Canon Image Runner 3320I Copier
System error E000
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press #
Press Set
Press Set
Press <
Jan 14, 2008 | Canon ImageClass D880 Copier
I have a Canon Image Runner 1670F
That is a fuser problem,lamp,or thermister.
Jan 10, 2008 | Canon ImageRUNNER 1670F Copier
Canon imageRUNNER 210S Copier Logo
156 people viewed this question
old marine
old marine
