Question about M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System
No rec mixer output thru Band In A Box.....can't monitor sound
When using audio input with mic or guitar in BIAB program, I can't monitor sound. The BIAB VU meter shows signal input, but no output. This gives me a Windows error message that says it's looking for mixer volume control, (and of course can't find one). I am able to record and play back, but cannot hear my playing while recording. When I access the M-Audio control panel there is no volume function (mixer) available for this input. The Windows volume kernel only has playback mixer vol for M-Audio piece incl wave, CD. There is no rec mixer volume avail (shown).
While visiting my local music store for help I noticed the store's computer showed an M-Audio control panel that did have a volume control. Since I am using the Audiophile USB, the Windows Control Panel has no Volume Control available, nor does the Audiophile for rec.
I have just downloaded the latest driver for both programs, just to be sure. The tech at M-Audio and the tech at PG Music (BIAB) both seem confused and can't answer this problem.
Dell Dimension 9150, Pentium(R) D 2.80GHz 1.00 G Ram
Windows XP, SP3
BIAB 2008
2 Suggested Answers
SOURCE: No Audio output from 410
no idea.any assistance?
Posted on Sep 12, 2008
Samson xp200
From the Owner's Manual, page 7:
2: Output VU meter - This three-segment bar meter shows the XP200 output
level. For optimum signal-to-noise ratio, set the Volume control (see #6 below)
so that program material is usually at or around 0 VU, with occasional but not
steady excursions to the red "+3 dB" segment.
http://www.samsontech.com/site_media/legacy_docs/ExPro_OM_4L_B_V4_1.pdf
Jan 03, 2014 | Audio Players & Recorders
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Vestax pmc07 pro powers up, but no output through amp or phones????
most likely one or some of the op-amps are blown. you are using the right ac adaptor too? sometimes when underpowered it will give a low output. also are you getting a read out on the vu meters? if so then most likely the op amps. if there is no read out on the vu meters, it could be the input stage. have you also tried your mic and aux in too?
my suggestion is, that if its under warranty get it fixed.
Aug 30, 2009 | Vestax Pmc07pro DJ Mixer System
How do you connect Audio Buddy to computer
You probably connect the Audio Buddy via a USB or firewire cable. I use both types of audio interfaces. Your mac will sense which bus has audio. Go to System Preferences panel and select sound. Select input. You should see your Audio Buddy listed if it is connected properly. You can set levels from this panel and test the device by looking at the two level meters. Speak into the mic; the level meters should move from left to right. Go to the output panel and chose your monitoring device. I prefer the built-in speakers, but you could also connect your monitor to the USB interface or even the Audio Buddy. If I need better quality monitoring I plug a mini cable into the earphone jack and use a desktop speaker. Don't try to use that headphone jack for anything but monitoring - the quality is not great. If the Audio Buddy software requires that you select an input source, always use USB, never line or built-in mic. Another way to capture audio from an Audio Buddy or similar device is to use Wiretap Studio Pro or Roxio CD Spin Doctor for audio capture. I use both.
Dec 03, 2008 | M-Audio M Audio Audio Buddy Microphone
No sound from the monitor or playback
check out where your monitors are receiving their audio from.is it from the tascam or the onboard or audio another interface.first choose an output for your sound,if you using the tascam as an output for your sound connect your monitors to the phones input in front and use the mono mix knob to swap between audio coming from your usb or computer.if you want to hear from your mic or guitar move knob to usb if you want to hear from computer as in playbck move it to computer.
Nov 21, 2008 | Tascam US-144 Sound Card
EMU 1616m (cardbus) not offerring its input sources to Reaper
While you probably solved this already here goes. I'm not familiar with reaper but most audio recording software can select between using windows wdm & ASIO. If you aren't set to ASIO you won't be able to see the Hi-Z (Dock A/Dock B) inputs. It looks like Reaper supports ASIO so that should be fine. If though you are using a program that doesn't support ASIO you need to use the EMU patchmix and 'patch' the input through to a 'wave' channel.
Mar 19, 2008 | E-Mu 1616M Sound Card
Low record level for guitar
first of all you want to have your guitar amp at a decent volume but too loud, just enough to be able to get a good signal. when you have done this turn up the gain on your mic channel so that your VU meter (level meter) on the recording software shows a reading of about half way up the meter. If you can not achieve this with the soundcard alone increase the gain on your channel in the software.
This sound guarantee a good signal but as with most recordings you will still have to boost the signal without it peaking. to do this use a compressor or a limiter and turn the gain up. if you use these dynamic effects correctly you will achieve the guitar level you want.
Jan 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Problem with guitar
1.make sure the guitar/mic switch is pointed to the guitar side. increase the guitar/mic level. increase the output level. 2.another thing you can do is check the "sound and audio devices" to see if everything is set to Edirol UA-4FX. If everything isnt, fix it so that it does. and remember to disable your computers stock sound card. Edirol UA-4FX is your new sound card from now on. 3. if thats not the case, try reinstalling the drivers. 4. If all of the above fail, you probably have a loose connection/ bad wiring in the guitar/mic 1/4" input. you can choose to open up the device and solder that yourself and possibly lose your warranty or have the entire unit replaced. Hope I helped! good luck!
Apr 30, 2007 | Edirol UA-4FX External Sound System
Open Questions:
M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System Logo
166 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
