Question about Hansol 500 A Monitor
Brightness My monitor is a Hansol 500A monitor and the brightness of the monitor is too low, how to improve it? please tel me about it. the button of brightness is set on full but the screen is dark.
  • mgmustafa Nov 22, 2008
    Thanks FixYa for the solution my monitor now work very good
    - mgmustafa
  • petunia_with Jan 09, 2009
    I have Hansol 920D with the same problem with brightness. It will work for this model also?
  • 348 Answers
Open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
Posted on Nov 22, 2008
  • pravin bhavsar
    pravin bhavsar Nov 22, 2008
    tacke care that dont touch inside monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My Hansol 710D monitor is very dark, despite putting brightness and contrast up to 100%. Thanks in advance.
if theres back straight line geting closer to the center and the brightness is dimming your moniter is going bad.
Jan 26, 2011 | Hansol 710 D Monitor
Hansol710p 17"Monitor color adjustment problem
wich is factory colour profile from hansol 710p ? thanks in advance p.s. jovica.tasic@hotmail.com
Jul 25, 2009 | Hansol 710 P Monitor
Birghtness problem
Not much you can do. This could be a defective monitor. play with the settings and if you still aren't satisfied then contact the manufacturer to give them the feedback. They may replace it for you.
Jun 03, 2009 | Hansol H530 15.1" LCD Monitor
How to fix brightness on hansol 920p if it is already on max in manu? is there some button in case to do that?
There are ways to bring the brightness up in a CRT monitor. These should only be attempted by a servicing pro. There are extremely high voltages involved.
Mar 24, 2009 | Hansol 920 A 19 in.CRT Conventional...
Desktop screen display goes blue
can u boot into the system?if not it can be solved if yes then there is a problem with ur monitor
if u cannot boot intoo the system load default or system restor tht u do ,......savio k frm mumbai savio_k20@yahoo.com let me know if u solved it
cheers
Jul 05, 2008 | HP D2835 17 in. CRT Monitor
Resolution hansol 730E
interesting, have you tried perhaps a monitor screen?
Feb 11, 2008 | Hansol 730E 17" CRT Monitor
Hansol Mazellan 500A is it not compatible with 128MB Video Card?
your monitor does not support the screen resolution that your windows install is set to. hook your pc back up to your computer guys monitor, and reduce the screen resolution, then hook it back up to your monitor.
Jan 08, 2008 | Hansol 500 A Monitor
Hansol 500 A Monitor Logo
210 people viewed this question
Top Hansol Computers & Internet Experts
ray gallant
Andre van Wyk
Andre van Wyk
Level 1 Expert
Zakari Elothmani
Zakari Elothmani
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
