2001 Chrysler Sebring Logo
Anonymous Posted on May 12, 2012
2.7 motor won't start I changed the plugs and it
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9174
Points
9
Have you calibrated those plugs well ? .050 inch its the gap calibration for that type.
  • Anonymous May 12, 2012
    Yes I gapped the platnuim plugs @.050 and the old ones were.022 or higher and were champion and it act like it wanted to turn over but started dragging. Spin fast then slow like it needs a jump
305 motor won't start it will crank but can't get
Is the the same engine that you replaced the plugs and wires on ?
Are the plugs getting spark ?
1998 GMC Safari van won't start.
Check your switch that runs to your aternator.make sure is grounded .if not get a sand paper and sand it down.also check the switch that plugs in to the alternator.
1helpful
Car won't start or engine turn over until tried 5 times or more
Check fuel pressure at motor with a gauge or scan tool data ,
if that is avail & see if it holds when pump is off
You have to change spark plugs every 3 years,change air filter & clean maf sensor once a year
If your combining your explanation of the problem,
then maybe you just have a bad battery
Dune buggy won't start. Very weak spark
Did you check out the rotor and distributor cap?
Car won't start 2003 Dodge Stratus sxt coupe cranks but won't start what could b the problem? I tried spraying starting fluid in the air system but it still won't start!
i would check and see if spark pluges are firing. you can take one out and plug into spark plug wire then let the bottom of the plug sit on engine and get someone to try to start while you look at the plug to see if there is any fire. if you have no fire or fuel it would be the crankshaft sencer. it could be the timing belt but the motor would sound different turning over then it used to.
Truck won't start at all changed starter have cleaned all electrical plugs truck won't do anything
try selionoid..bump the neg and positive together with a screwdriver..if it cranks walah go get another selionoid
What would cause 2.7 motor to shut down and won't
did the timing belt let go?sounds like it
My 1998 E350 engine shuts down in 10-15 minutes when the airconditioner is switched on. The won't start immediately, even with a strong battery but it will start after a while. What could be the...
probly need a tuneup-change plug wires and distributer cap--------clean throttle body and idle control motor---------get a scan and data stream done as an option
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
