Question about Ovens
Older Kenmore oven- door locked by itself
We have an older Kenmore gas/electric oven. The door locked during the night and it keeps making a clicking noise. Self-clean was not set. We unplugged it and it came right back on. On the LCD panel "lock" keeps flashing. Please help. I have the same problem! The model number on ours looks like this: 911.3138819 (found on the inside of the door).
We can't use our oven.
  • 1 more comment
  • stretchkmh Nov 21, 2008
    We were able to unlock it by using a yard stick to push the lever so now we can open it
    BUT we cannot close it tightly. The LCD panel now says "door" whenever we turn the oven on.
    (so the oven will not heat because it thinks the door is open)
  • stretchkmh Nov 22, 2008
    Now the latch is in the way so that's why it cannot close tightly.
  • Anonymous Mar 21, 2009
    Older (1991) Kenmore electric wall oven locked when we had a short power outage. Door locked and will not open. Ran through the cleaning cycle to see if it would unlock, well no go still mentions "lock". Turned power off at the curcuit breaker thinking the lock may go off, no go again. If I move the door up and to the right I can unlock it but then the top door latch sticks out and you cannot turn the oven on as it now mentions "door" because the door is not all the way closed. YIKES........please HELP!!!!!!!
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Posted on Mar 16, 2009
The LCD panel display door lokced ?????
Posted on Dec 25, 2008
Did the self cleaning. Now it has a F 3 code & door will not unlock.
  • Check warranty to make sure it has expired.
  • Disconnect power for 30 seconds and see if oven will reset the electrical lock.
The following link describe for Kenmore several procedures to disengage the electrical lock securing the door.
It is unfortunate that during the self cleaning cycle the stress levels at the elevated temperature premature failure appears to occur.
How to Clear the Oven Lock Mechanism on Kenmore Stove
The F3 error is most likely the temperature sensor that protrudes into the oven near the top usually on the left. Don't be confused there can be two probes that enter the oven. One is the over temp like not to exceed type of switching device and the other is the actual sensor that maintains the temperature at the set point.
There is a procedure to replace this sensor from inside the oven. I have had only limited success doing this repair in ovens from the front. Newer ovens are equipped with a plug that is easier. In all cases ensure that the plug is pushed through away from the oven wall. In older ovens I have had to pull the built in ovens to accomplish the work from the back to ensure a good connection using wire nuts... The sensor in the second photo does not have a plug so small wire nuts that will fit through the back of the oven are used.
26060093-3hiy01xauopzuspf4owyz2yd-3-2.jpg This second link is a suggestion that the use of the self clean feature is a concern, On two occasions I have had oven problems right after using the self clean cycle.
http://www.thekitchn.com/why-you-should-almost-never-use-the-self-cleaning-function-of-your-oven-175110
Jan 19, 2016 | Ovens
How do I fix an oven lock on a self cleaning Kenmore built in dual ovens? The oven locked up during a clean oven cycle and will not unlock.
Some ovens will not open unless the clean button or knob is set to Clean. Make sure you are trying to open in correct direction. Try turning it on and off and press down on the latch while trying to open. I would not use a crow bar, this can be done. If you unplug it and wait for it to reset after about 30 seconds it might let go. Just keep playing mine stuck once and it was because I flipped the clean switch off an turning it back on ready to start the cycle pulled back on it and it opened. Oh I remember my neighbor had a older style dial clock and she set the clock for a certain time to stop and the door would not open until she ran the clock to that time spot. Hope this helps. I wish I knew how to open it from the electrical side but I dont.
Jan 30, 2015 | Kenmore Ovens
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
    Hi.
    the oven may have locked in consequence of the self cleaning cycle.
    After unplugging, allow the oven cooling down for few hours.
    If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
    Parts must be tested to discover the fault.
    Call Kenmore at the number listed on the owners manual.
    Regards.
    Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
    The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
    Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Older oven stuck on Clean and door is locked.
    does your oven have a lift up top if does. lift up burns and silver box open box and you can unlatch the lock. hope workds
    Apr 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore oven 41775790 locked door
    after self cleaning with the racks still in oven, i cannot get the oven door open, locked down, does this have something to do with the racks left in oven during cleaning. what do i need to do
    Jan 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Oven timer
    We bought an older home with an electric Amana oven. Problem is, the timer on the oven goes off whenever it wants to. Usually, during the night! How do we stop this besides unplugging the thing every night?
    Jul 05, 2008 | Ovens
    wanna say you have a faulty latch/self clean assy. however the erc( lcdd panel could also send eratic power supply to latch mechanism)
    Mar 09, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Self cleaning oven directions
    Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
    Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    482 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
