My washer is always unbalanced .
I have even run it without a load of clothes in it. When it spins things all over the house vibrate. It's a maytag.
  • vdoran Nov 21, 2008
    the adjustable feet on the maytag washer are adjusted properly so that is not the problem.
ginko
  • 19396 Answers
SOURCE: load starts banging like it is unbalanced
Check first the machine balance, to ensure the machine is at level and well balanced and that is not the problem.
If you already inspected springs and strut, then the problem is usually the drum bearing, or the drum bearing spider that has broken.
You can superficially check if there is a problem with the drum bearing by spinning the drum with the hand to check if there is excessive play.
If you found oil under the machine, check also that the support for the motor and motor gear box under the bearing is not damaged, and any of this part is banging again the chassis, this can cause oil leak, and machine shaking.
The most common is a bad bearing.
Posted on Mar 27, 2009
SOURCE: Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Posted on Dec 23, 2007
ngfam1
  • 639 Answers
SOURCE: Maytag Performa Washer
Whirlpool is good but Speed Queen is the best with the best warranty in the industry!
Tested to wash 8 loads a week for 25 years!
3 years parts and labor compared to all others with only 1 year! And 10 years for the transmission not 1 year like all the rest!
only 34 gallons of water used in the top loader and 13.9 gallons in the front loader.
I'm 53 and I'm not buying another washer again!
YES I SELL THEM AND EVERYONE WORKING IN MY STORE HAS ONE! There are plenty of more features!
Speed queen is used in laundry mats all over the world!
So now that I reallllly saved you, GIVE ME THE BEST RATING SCORE HERE AT FIXYA!!
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Posted on Aug 24, 2008
  • 12 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Posted on Nov 17, 2009
kvhappliance
  • 218 Answers
SOURCE: F20 ERROR ON MAYTAG FRONT LOAD WASHER
Is it filling with water?
Posted on Mar 20, 2010
My bravo washer is not starting a cycle when I press start button. Also water is still in tub from last load that did not drain.
Sounds like you washer is trying to spin out and becoming unbalanced and cutting off.. Move timer to spin and see if water spins out. If so try running a load and say with it so if it becomes unbalanced you can arrange clothes before returning timer runs out.
Feb 20, 2016 | Maytag Dryers
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Ds codemkeeps coming up even though the door is shut
The "dc" error code indicates an unbalanced load is preventing your washer from spinning properly. Try redistributing the load, then press the Start/Pause button. If the load appears well-distributed, you may need to make adjustments to the leveling legs to make sure the washer is properly leveled, removing the clothes and running a spin only cycle to make the necessary adjustments. Once firmly leveled, be sure the plastic leg locks are tightened to prevent them from vibrating loose.
Apr 14, 2014 | Samsung WF337AA Front Load Washer
Maytag A511 washer tub vibration
The tub should not become unbalanced over time. There suspension springs may wear unevenly, however. Replace all of the suspension springs and it should be fine.
Jul 31, 2009 | Whirlpool LSQ8000 Top Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Spin Cycle
SOUNDS LIKE THE MAHINE IS NOT LEVEL LIFT THE WASHER UP AND LET DOWN EASY IF YOU HAVE SELF ADJUSTER IT NOT YOU MUST ADJUST THEM YOURSELF THE SQUEAK
COULD BE DUE TO UNBALANCED WASHER OR BEARING IN THE MOTOR
Oct 27, 2008 | Maytag PAV2300 Top Load Washer
Excessive wobble
Sep 06, 2008 | Maytag Neptune Washer
Loud knocking noise at end of spin cycle
To allow for unbalanced loads and reduce vibration in the floor of the house, the outer tub is suspended by various means. Some machines use a heavy rubber ring, others use spiral springs but either of those can, after a heavily unbalanced load, unhang themselves or in the case of the rubber suspension, the rubber tires and rips.
If you remove the back panel (10-12 screws) and look inside while pushing the tub side-to-side, you should be able to find the suspension and inspect it with good light.
Apr 17, 2008 | Kenmore 22622 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
